[Z06] Delrin Bushings anyone?
I've been researching this mod for a few days now and decided to do my own post after not getting the information I'm looking for. I see a few people going with the poly bushings for their control arms but want something more stiff without much flex. That seems to be what people are after when doing this upgrade anyway. My car is a 09 Z06 and I do mostly street driving but go to the track every once in awhile, it's not my daily driver. I however don't want my car riding like crap either, I can sacrifice some driveability for performance though. Anyone here running delrin and care to give me your opinion? Looks like I can get a nice set from Ridetech for about $900.
I think the Derlin option is appropriate for a race or dedicated track car - for a street car that will see some miles, not so much.
I think you should stick with the stiffer rubber / poly options.
I would talk with LG.
My opinion is stay stock, or go ***** out and do the monoballs.
v8sten (09-30-2021)
So you switched out your delrin bushings for something else?
Do Delrin, used it over several cars when doing bushing upgrades. My only complain is always the ****ing noise the poly bushing replacements make..
Never had an issue with the Delrin stuff.
Hmm. so the ride is fine, this is what I was thinking. I was reading somewhere that you could feel every rock in the road with delrin, but I want something that's good and don't feel like breaking the pocketbook on them. A set of delrin from Ridetech is $900 and the poly setup from Pfadt is $579.
Former Vendor
You may feel a little more NVH, but not feel any difference in ride quality. Delrin will allow the suspension to move freely, but not stiffen the overall ride. I think a lot of people thinks it rides rougher due to the added NVH felt. I run them in my daily driver and can tell you that it didn't make the ride harsher, but I do feel a little more in the steering wheel. We run a Teflon infused Delrin so that they allow for free movement and no maintenance. Feel free to give me a call @ 812-481-4742 if you have any questions about Delrin.
The following 2 users liked this post by Rodney@ridetech:
GoJuice505 (04-16-2020),
v8sten (09-30-2021)
Just the thread I was looking for. I already bit the bullet and purchased a Delrin bushing kit for my 2002 Z06. My budget suspension upgrade approach included the Delrin kit plus the DRM Bilstein shocks. My purpose is to improve handling and to have a more track-ready car when I go to the track a few times each year. I don't mind sacrificing some ride comfort or noise for less body sway and improved cornering. It's all about form following function IMO.
Besides, I don't have a wife to contend with for getting into the car. My GF doesn't know what she's in for as the car has been on a rack since we met 3 weeks ago. It's now off the rack and ready to rumble!
Ride on fellow Corvettes!
Borg Motorsports (09-17-2021)
Supporting Vendor
We use real Delrin (acetal homopolymer) as opposed to the more generic acetal resin (acetal copolymer). The homopolymer is significantly stronger, stiffer, and has a much better wear resistance than the copolymer. It's a little more expensive as a material than the copolymer and is slightly harder to find. It's more difficult to manufacture as a material and sometimes has voids in the center that you need to watch out for. These are easy to see once the material is machined and those parts can be scrapped. It adds to the cost of our kits, but I feel that it results in a substantially and objectively better end product for our customers. Both our Teflon impregnated (Premium) kits and our standard Delrin kits use Delrin homopolymer. The Premium kits also use Teflon fiber impregnated material as opposed to the Teflon powder material which can be a little weaker and a little less durable than the fiber version.
For reference on prices, our Standard Kit is currently $829 for the C6 Z06 and the Premium Kit is $1249, (follow the links to see pictures, more details, and reviews). Make sure to look at prices for the C6 Z06/ZR1 kits (from any manufacturer) since the higher-end C6's have aluminum frames and require different rear upper control arm mounts that are more machining intensive. The steel frame kits are much simpler and are therefore cheaper.
In full disclosure, we are out for another week due to some shop vacation and business travel but will be back shipping products on 9/29. I do have all the parts needed for a C6Z Premium kit but would need a few days to manufacture a Standard kit. If you have any questions, feel free to DM or email at lane@borgmotorsports.com.
__________________
Borg Motorsports
www.borgmotorsports.com
Lane Borg - Owner
2012 AS Solo National Champion
2014 BS ProSolo and Solo National Champion
Borg Motorsports
Lane Borg - Owner
Update to a post below,
I now have many road miles on the kit, and it is not harsh at all. The car is much nicer to drive and predictable if you like to have fun on the back roads. I have recently noticed a squeak on the right rear, so maybe Lane can advise on that, but it is not annoying.
Posted on 3/31/2021
I’ll give a thumbs up on here to Lane and Borg Motorsports and David Farmer, who did the alignment on the car.
I’ve had a few good runs with car in the hills of NC.
No rattles or squeaks. The car is much more direct in its feedback and does not wiggle around. the kit does NOT make the car harsh for the roads. IMO the car feels like a corvette should.
I also installed, DRM shocks and AMT camber kit along with the bushings.
Posted on 3/31/2021
Supporting Vendor
Posted on 3/31/2021
Posted on 3/31/2021
The squeak is something that pops up on some aluminum frame cars. Apparently there are some rear upper control arms that have different dimensions than nominal and it can cause a squeak. Shoot me an email and we can determine what needs to be adjusted and I can get a custom set of bushings machined. A spacer or some grease can also be a quick solve if you want a fix you can implement right now.
This is perfect, I am looking at both Poly & Delrin for mine and I definitely struggle making a decision. There's a $200 price difference between the two which is quite a lot, but the general feedback seems to push toward Delrin... and I get what you're explaining Lane. Decisions decisions...
