[Z06] LS7 OBDII Codes?
Received 8,915 Likes
Here is a list of the Engine Codes from the 2009 Service Manual. FSM only provides the Code Number the name is seen once you open the link to the diagnostic procedure that goes with the code or group of codes.
DTC P0016
DTC P0030, P0036, P0053, P0054, P0135, or P0141
DTC P0033
DTC P0050, P0056, P0059, P0060, P0155, or P0161
DTC P0068 or P0121
DTC P006D
DTC P0096
DTC P0097 or P0098
DTC P0102 or P0103
DTC P0106
DTC P0107 or P0108
DTC P0111
DTC P0112 or P0113
DTC P0116
DTC P0117 or P0118
DTC P0120, P0122, P0123, P0220, P0222, P0223, or P2135 (W/LS3 or LS7)
DTC P0120, P0122, P0123, P0220, P0222, P0223, or P2135 (W/LS9)
DTC P0128
DTC P012B
DTC P012C or P012D
DTC P0131, P0132, P0137, or P0138
DTC P0133, P0134, P0140, P1133, P2270, P2271, P2A00, or P2A01
DTC P0151, P0152, P0157, or P0158
DTC P0153, P0154, P0160, P1153, P2272, P2273, P2A03, or P2A04
DTC P0171, P0172, P0174, or P0175
DTC P0191
DTC P0192 or P0193
DTC P0201, P0202, P0203, P0204, P0205, P0206, P0207, or P0208
DTC P0230 (without LS9)
DTC P0230 (with LS9)
DTC P023A
DTC P025A
DTC P0300-P0308
DTC P0315
DTC P0324, P0325, P0326, P0327, P0328, P0330, P0332, or P0333
DTC P0335
DTC P0336
DTC P0340
DTC P0341
DTC P0351-P0358
DTC P0420 or P0430
DTC P0442
DTC P0443 or P0449
DTC P0446
DTC P0451, P0452, P0453, or P0454
DTC P0455
DTC P0496
DTC P0506 or P0507
DTC P0601, P0602, P0603, P0604, P0606, P0607, P060D, P062F, or P2610 (Set in ECM)
DTC P0601-P0604, P0606, or P062F
DTC P0641 or P06A6
DTC P0641 or P0651
DTC P0650
DTC P0685, P0689, or P0690
DTC P069E
DTC P0700
DTC P1174 or P1175
DTC P1255
DTC P129D
DTC P129F
DTC P12A0-P12A2
DTC P12A4-P12A6
DTC P12A7
DTC P1380 or P1381
DTC P1400
DTC P1516, P2101, P2119, or P2176
DTC P164B or P164C
DTC P1682
The following codes go with the 6 speed manual transmission:
DTC P0502 or P0503
DTC P0712 or P0713
DTC P0801
DTC P0803
DTC P0806
DTC P0807 or P0808
DTC P080A
I am attaching a PDF with the overall listing of 2009 codes for everything on the car including the OBDII codes. The list is huge and the codes are intermixed so I will let you sort out the powertrain codes. Only a few of the powertrain codes aren't LS7 codes. The few that aren't are LS9 codes or A6 codes and are noted as such. The 2008 and earlier cars had a slightly different set of codes due to having a different ABS system/EBCM/Wheel Hubs.
Bill
DTC P0016
DTC P0033
DTC P0068 or P0121
DTC P006D
DTC P0096
DTC P0097 or P0098
DTC P0102 or P0103
DTC P0106
DTC P0107 or P0108
DTC P0111
DTC P0112 or P0113
DTC P0116
DTC P0117 or P0118
DTC P0128
DTC P012B
DTC P012C or P012D
DTC P0191
DTC P0192 or P0193
DTC P023A
DTC P025A
DTC P0300-P0308
DTC P0315
DTC P0335
DTC P0336
DTC P0340
DTC P0341
DTC P0351-P0358
DTC P0420 or P0430
DTC P0442
DTC P0443 or P0449
DTC P0446
DTC P0455
DTC P0496
DTC P0506 or P0507
DTC P0641 or P06A6
DTC P0641 or P0651
DTC P0650
DTC P069E
DTC P0700
DTC P1174 or P1175
DTC P1255
DTC P129D
DTC P129F
DTC P12A0-P12A2
DTC P12A4-P12A6
DTC P12A7
DTC P1380 or P1381
DTC P1400
DTC P164B or P164C
DTC P1682
DTC P0502 or P0503
DTC P0712 or P0713
DTC P0801
DTC P0803
DTC P0806
DTC P0807 or P0808
DTC P080A
Bill
The following 3 users liked this post by Bill Dearborn:
