[Z06] Rubber Bushing on Lowering Bolt Shreded
So on my way home last week from a trip to the Fl Keys I start hearing like a banging from my drivers side rear suspension.
A day later I get under the car to see what I see & it seems that the rubber bushing on the lowering bolt is broken.
I bought the car already lowered, & it seems pretty low, so I'm guessing original owner cut some of the ribs.
Anyways, I guess I need to get new bolts. Now the only questions is which do I get?
I know GM only sells them with the whole spring assembly, but there are a number of aftermarket options available.
I was looking at Zip bolts. The price seems very reasonable & I like that bushing design they have, but they seem to be on back order at the moment.
Second ones I saw were Pfadts but those are almost 4x the price of Zips, but those do seem to have a nice design also, with the bolt on a pivot.
What do you guys suggest?
http://m.ebay.com/itm/VMS-05-13-CHEVROLET-CHEVY-CORVETTE-VETTE-C6-LOWERING-KIT-STAINLESS-STEEL-BOLTS-/311518710665?nav=SEARCH
thanks
I asked about how low they go, because the common aftermarket bolt doesn't quite lower the Z in the front as much you'd think. The delrin padded bolts above look about half the height of other aftermarket bolts and was just curious if it gave the car a little more low, or if the pivot prevents it.
Rex915 (09-20-2016)
I've been checking this thread for updates since June. What is the hold-up?
My rubber pads are trashed too, but I don't want lower at all. I would order these if they can do factory or higher ride height.
guys, sorry....I ordered the bolts & just have them sitting there. haven't had time to install them with a house remodel (by myself) & all that.
I got lucky that I was able to install that Android HU the Mrs. gave me for our anniversary.
They do look nice, and while I like the integrated pivot where the pad meets the bolt to assist with suspension articulation...but it could also potentially be a wear/failure item down the road IMO. Either way...I agree with others that is a potentially good design.
