[Z06] Issue and frustrated with MSD Intake.
#42
#44
Pro Mechanic
Pro Mechanic
HPT does not support manifold volume unless you make a special request to their tech support and even then, there is no promise that you'll get it. I never did and I spent two weeks trying, making repeated requests.
I was working with an E38 in a 2012, which I advised HPT Tech Support. They asked for my OS no. I supplied it. They asked for the calibration ID for the the manifold volume parameter. I could not provide that because I did not know what ID was nor could I find the information. I got tired of the hassle with HPT tech support in the issue and finished the cal with EFILive. I was thinking...come on guys, the cal is there, just put access to it in the Editing app!
In my book, all this means that HPT, which otherwise is great software, does not support manifold volume. if EFILive can put it in their editing app and require no special request process, then there's no reason HPT can't do that, too.
Let me know what you think.
#45
No "Seb" you are wrong.
I was working with an E28 in a 2012, which I advised HPT Tech Support. They asked for my OS no. I supplied it. They asked for the calibration ID for the the manifold volume parameter. I could not provide that because I did not know what ID was nor could I find the information. I got tired of the hassle with HPT tech support in the issue and finished the cal with EFILive. I was thinking...come on guys, the cal is there, just put access to it in the Editing app!
In my book, all that means HPT, which otherwise is great software, does not support manifold volume. if EFILive can put it in their editing app and require no special request process, then there's no reason HPT can't do that, too.
Maybe you could download the 3.2 update and give it a try.
Best regards,
Seb
#46
Hib, I think that like Michael stated previously it was OSspecific maybe ... But like he also stated, the 2010 C6 Z06 OS in the 3.2 version are already there and he didn'T ask to Hp tuner to add it.
Best regards,
Seb
Best regards,
Seb
I think Hib just happened upon the wrong person, or maybe the issue wss with how the question was worded. They added it for me right after v3.x was released
So, to say it "isn't supported" is an un-true statement.
Now, maybe someone with a LOT of spare time on their hands can log with it set to default and with it set to the larger value, see if there is a detectable difference.
#47
Already did that, altho it was with the FAST. Nothing, notta, zip, was either felt, or detectable in any logs. But having said that, I am using the HPT custom OS, with real VE tables, and none of the coefficients in play.
#48
Have you played with the new VVE setup in v3.x yet? I am about to finalize everything and I plan on using it. I also noticed you can save different versions for flaps open / closed, etc., although that is more of a curiosity.
#49
99% sure the VE open and VE closed is doing with intake flaps, not exhaust, and last time I checked, only one of them does anything. Thats how the custom OS has been for the past ~6-7 years.
#50
Yes, I've remote tuned two modified Z06's now using the new VE editor. Works incredibly well. Much easier than the BlueCat tool and way-mo-betta than EFI Live's version. Although, it will not automatically establish the boundaries that the BC tool will do for you. Easy enough to figure out where to set them after a couple runs, so that's not a big deal.
#51
Some GM truck intake manifolds have this feature from what I gather. I don't know for sure, cause I have not tuned a vehicle with it.
#52
Never requested or talked to HP, and just checked and 3.2 has manifold volume FYI
#54
I forget which one it actually uses, I think it is the IMRC closed, but I just copy/paste and make sure they are all the same.
#55
I was messing with it early. I doubt it matter, and wouldn't bug the tuner over something like that.
