C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Z06 Exhaust rattle
Old 07-05-2016, 02:47 PM
JohnAlley
JohnAlley's Avatar
Default Z06 Exhaust rattle
Finally found the rattle in my exhaust just don't know how to fix it. It appears that the springs that hold the hanger bracket is hitting the diff. I can see some small rub marks on the diff next to the spring. Anyone have a suggestion as how to fix this problem ? I tightened up the bolts that hold the springs and the rattle is not as bad but still can hear it. Anyway to insulate the springs from the diff ?
I also put a spring between the springs to increase tension but still no help with the rattle.
Old 07-05-2016, 03:11 PM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Loosen all the clamps and adjust system for more clearance.
Old 07-06-2016, 09:47 PM
548chevelle
548chevelle's Avatar
My '11 just started doing the same thing last week. I tracked it to those springs because when I hit a tailpipe I can hear those springs rattling. Hafta get underneath and adjust.
Old 07-08-2016, 09:29 AM
grcor
grcor's Avatar
Check out this link https://www.corvetteforum.com/forums...r-springs.html
To Z06 Exhaust rattle
Quick Reply: [Z06] Z06 Exhaust rattle
