[Z06] How much brake pad left?
This is the best picture I could get without
taking the calipers off. Any idea how much brake life I have left? Stock pads and about 1/8" between part arrow is pointing to (wear indicator?) and rotor. 7,000 miles, aggressive driving.
Jesse
Front <br/>
Jesse
Front <br/>
Your done, replace now before you screw up the rotors
True
My stock pads had the backing plate that did not cover all of the brake pad, only the upper half.
Funny the posiquiet pads covered almost 3/4 for more even wear. Whether they do or not will be seen.
If you like low dust and don't mind losing a little braking the Duralast Ceramic pads work well. If you want greater braking, then you will likely need a pad that dusts heavier and has more squeal. Street pads are not suited to track work and vice versa. Some can get away with a pad that works on the street and at autocrosses.
Supporting Vendor
St. Jude Donor '11,'13
The Carbotech 1521 is a low dust pad that is rotor friendly and performs like OEM if not better under thresh hold braking and last longer. 100% non-corrosive dust will not harm your paint or wheels. This pad also contains NRS technology. Carbotech uses NRS technology on all C4, C5, C6 & C7 front and rear brake pads.
Here is a link to explain further what NRS technology is exactly: http://www.nrsbrakes.com
If interested let me know I will be happy to help you.
Carbotech™ Bobcat 1521™ The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Ordered the 1521s for the front from Adam! I'll look on how to measure the rotors unless someone wants to chime in. There is a very tiny lip on the outer portion of the front rotors where the brake pads do not come in contact with.
Just did brakes in March @44K on my '08.
Trusted wrench said 40-42K for Z06 front brakes about normal from what he's seen. Said I drive lightly, he said it doesn't matter.
Was advised front discs needed replacing, also.
Running fingernail across disc revealed all manner of light grooves. Back pads & discs just fine. Will do 'em March '17.
FWIW used OEM pads/discs and yes, dusting like it were new but does stop smartly. You need carbon.
Landru (07-13-2016)
Supporting Vendor
This may help take a look. http://www.101corvetteprojects.com/2...rvette-c6-z06/
Got the front pads changed to the Carbotech 1521s! Thanks to Adam and all. After I realized to take the aluminum brake pad cage out of the caliper before installing the new single piece pad it went smoothly. Rotor thickness was good at approx. 31.75mm on each side-at the outer lip of the rotor it read 32.15mm.
Thanks, Jesse
Thanks, Jesse
I appreciate your business pads have shipped: thumbs: If you have rotor concerns please call me back.
How thick are your Bobcat pads?
And do you know the well kept secret as to how thick the OEM pads are?
DH
Received 8,915 Likes
With an 1/8 inch (.125) between the squealer and the rotor you should have plenty of pad life left. A new pad is only .570 thick and the recommended change out thickness is 2/32 (.0625). However, those padlets taper and you can't always tell their minimum thickness by looking at the wear sensor or by pulling the wheel and looking from the top of the caliper. Pull the wheel and the caliper and inspect the pads for taper. Since they taper based on their position in the caliper you can extend the life of the pads by swapping them around in the caliper to compensate for the taper.
Bill
Bill
... and the rears can be moved to the front, so you'd have 4 good rears and the best of the front 12 in the front and the most worn moved to the rear, if you want to maximize pad use.
