[Z06] Powershift vs. Granny-shift
You don't even need that. You can adjust the tune very easily with hptuners or similar. Many people power shift without even touching the tune. I personally tuned my car for it and love it. One of the best mods I've done!
And yes, I have a WOT box. It worked amazing in my cobra, and just as amazing in my ZO6. When you get it (if you get it), buy it directly from John on his site. I'm not sure if he's a vendor here and I don't want to get pee-pee slapped for posting a link. Google N2MB Wot box, and his will be the first site that comes up.
Could you please explain how you "tuned" for powershifting? I'm quite familiar with the scalars and tables in HPs software, and I don't know how cutting RPM at WOT is possible with the available tables.
I don't usually powershift as to not break anything, but crap breaks anyways sooo....
Can you explain how you set up the programming?
For WOT shifting, some have used HP Tuners to set the park/neutral limiter to 6500 +/- RPM, so when the clutch pedal is depressed the computer tries to pull the RPM's down to that set value...usually by pulling spark. This allows you to keep the throttle blade wide open with fuel spraying, with the accelerator matted.
For me, I had enough seat time in my car that I had pretty good hand/foot coordination so I could row the gears while lifting slightly to help the synchro mesh. As soon as you push in the clutch, you've decoupled the engine from the rear wheels anyways so having the engine rev freely into the limiter doesn't do you any good. When the clutch is let out at WOT and the clutch bites, you either shock the tires out of traction or pull the engine RPM's down to whatever the car's driveline gearing will let the engine have anyways.....the same RPM your "granny shift" will accomplish.
WOT shifting makes sense to me for f/i cars (especially turbo) where you need to maintain the boost pressures at the manifold/throttle blade....N/A and stock tranny, not so much IF you have the skills.
that's my .02
that's my .02
If a RPM device is needed to powershift, the shift isn't being performed right.
But hey, some people just don't need to care because they never miss a gear.
You don't need a WOT box in your vette... The people talking about doing it through HP tuners are right and it's the best way to go ... That's what I've had done... I had a wot box and the car actually went slower... I almost always power shift my car when racing and I have zero issues... My transmission was looked at when I swapped out my diff and it was perfect after over 50 passes power shifting...
Everyone has an opinion I guess but I wouldn't power shift a street car without having the No-lift shift
feature.
i bet the new M7 tranny totally changes the confidence level of drivers in this regard though. My T-56 is pretty darn clunky at times. Need that MGW shifter...
feature.
#35
Never did get a PM'd response about HP tuning...
Either way the WOT box is better because not only can you powershift at any rpm (gets input from the clutch pedal) and adjust how long the rpm kill is on (also has a default mode which is faster than trying to find a good MS delay), it also is an adjustable two step launch controller (from 1K-14K RPM) and nitrous controller, all of which are adjustable WITHOUT needing a retune. Meaning you can adjust launch RPM from pass to pass with just the push of a button. The nitrous control alone justifies the purchase price (especially if you're a nitrous car LOL!). The same CANNOT be said for HP tuning about features, function, or ease of use.
I've never met ANYONE slower at the track AFTER the install of the WOT box. Perhaps the previous poster just didn't have the best settings to run faster. I personally picked up 4 tenths in my mustang...haven't had a chance to take her down the track installed in the Z yet.
#36
How does that device ensure the driver doesn't shred gears during a power-shift?
#37
I had it on the lowest setting... I even confirmed it with my laptop... Had a N2MB... As for how it was done through HP tuners I don't know exactly... My tuner James Short of Shortuning did it... Call and ask them...
#39
I'll just explain here so people stop PMing me:
The main thing you change, as someone already mentioned, is reduce the neutral and park rev limiters to something lower than your actual limiter (i.e. 500-700 RPM lower). The exact delta isn't too critical.
Then most will want to adjust the control method to pull spark only, so make spark enabled and fuel disabled. I personally also changed the switchover to 10 and the cutoff hysteresis to 25 rpm.
I also have my extreme cutoff 100 rpm higher than my limiter in all gears and the extreme resume 20 rpm above that same limiter.
That's it! Takes less than a minute to make these changes and it works great. It's probably worth pointing out that these setting will making speed shifting normally, not as good. It'll feel less smooth.
#40
