[Z06] What gains to expect with MSD/Fast??
Currently looking into purchasing a 2007 Z06 with AHP stage 4 head package, BTR stage 3 cam, AR long tubes w/cat, Borla Atak.. Car has stock/ported intake manifold and stock/ported throttle body
What gains are to be expected with..
1) MSD ported intake manifold and/or FAST 102 ported
2) NW 102 throttle body
and
Dsteck Flex fuel Kit
ID850 injectors
Walbro 450/465
What is the most bang for your buck mod with this setup?
and
ID850 injectors
Walbro 450/465
Get yourself a "Mamomfied" MSD and NW TB combo, and I believe you'd see another 30-35 rwhp over your current config.
From my understanding, nothing unless you've really upped the compression. See if the heads had been milled and/or what the current compression ratio is for the car you're interested in.
Mine were right at 20 rwhp with the MSD and Fast from the testing was half of that. The MSD looks better too not that it matters but sure makes the decision easier. Mine also were not ported. I have enough rwhp that I will use so I did not port or go bigger on the throttle body either.
Question... did you have to buy a cuppler to make the CAI boot slide onto the 102 TB?
I have a halltech 103 air intake, my shop was able to reuse the halltech silicone coupler that fit the stock throttle body on the nw102.
-jp
