[Z06] My turn to ask for help - GM wiring color codes
I have a project I'm working on, and I have all the factory manuals.
It MUST be in the volume somewhere, but in my impatient 9 and a half mins, I couldn't find it.
Here are the codes I need the mappings to, and my edumacated guesses (although what I am after is a master reference chart to validate and have it handy for future projects).
L-BU = Light Blue ??
D-BU = Dark Blue ??
BN = Brown ??
TN = Tan ??
D-GN/WH = Dark Green w/ White stripe ??
D-BU (on another connector) = Dark Blue ??
Thanks in advance!
D-BU = Dark Blue ??
BN = Brown ??
TN = Tan ??
Thanks in advance!
Try the Abbreviations and Meanings section
Abbreviation Meaning
A
A
Ampere(s)
ABS
Antilock Brake System
A/C
Air Conditioning
AC
Alternating Current
ACC
Accessory, Automatic Climate Control
ACL
Air Cleaner
ACM
Air Conditioning Module
ACR4
Air Conditioning Refrigerant, Recovery, Recycling, Recharging
AD
Automatic Disconnect
A/D
Analog to Digital
ADL
Automatic Door Lock
A/F
Air/Fuel Ratio
AH
Active Handling
AIR
Secondary Air Injection
ALC
Automatic Level Control, Automatic Lamp Control
AM/FM
Amplitude Modulation/Frequency Modulation
Ant
Antenna
AP
Accelerator Pedal
APCM
Accessory Power Control Module
API
American Petroleum Institute
APP
Accelerator Pedal Position
APT
Adjustable Part Throttle
ASM
Assembly, Accelerator and Servo Control Module
ASR
Acceleration Slip Regulation
A/T
Automatic Transmission/Transaxle
ATC
Automatic Transfer Case, Automatic Temperature Control
ATDC
After Top Dead Center
ATSLC
Automatic Transmission Shift Lock Control
Auto
Automatic
avg
Average
A4WD
Automatic Four-Wheel Drive
AWG
American Wire Gage
B
B+
Battery Positive Voltage
BARO
Barometric Pressure
BATT
Battery
BBV
Brake Booster Vacuum
BCA
Bias Control Assembly
BCM
Body Control Module
BG
Beige
BHP
Brake Horsepower
BK
Black
BLK
Black
BLU
Blue
BN
Brown
BP
Back Pressure
BPCM
Battery Pack Control Module
BPMV
Brake Pressure Modulator Valve
BPP
Brake Pedal Position
BRN
Brown
BTDC
Before Top Dead Center
BTM
Battery Thermal Module
BTSI
Brake Transmission Shift Interlock
Btu
British Thermal Units
BU
Blue
C
°C
Degrees Celsius
CAC
Charge Air Cooler
CAFE
Corporate Average Fuel Economy
Cal
Calibration
Cam
Camshaft
CARB
California Air Resources Board
CC
Coast Clutch
cm³
Cubic Centimeters
CCM
Convenience Charge Module, Chassis Control Module
CCOT
Cycling Clutch Orifice Tube
CCP
Climate Control Panel
CD
Compact Disc
CE
Commutator End
CEAB
Cold Engine Air Bleed
CEMF
Counter Electromotive Force
CEX
Cabin Exchanger
cfm
Cubic Feet per Minute
cg
Center of Gravity
CID
Cubic Inch Displacement
CKP
Crankshaft Position
CKT
Circuit
C/Ltr
Cigar Lighter
CL
Clear
CL
Closed Loop
CLS
Coolant Level Switch
CMC
Compressor Motor Controller
CMP
Camshaft Position
CNG
Compressed Natural Gas
CO
Carbon Monoxide
CO2
Carbon Dioxide
Coax
Coaxial
COMM
Communication
Conn
Connector
CPA
Connector Position Assurance
CPP
Clutch Pedal Position
CPS
Central Power Supply
CPU
Central Processing Unit
CR
Cream
CRT
Cathode Ray Tube
CRTC
Cathode Ray Tube Controller
CS
Charging System
CSFI
Central Sequential Fuel Injection
CTP
Closed Throttle Position
cu ft
Cubic Foot/Feet
cu in
Cubic Inch/Inches
CV
Constant Velocity Joint
CVRSS
Continuously Variable Road Sensing Suspension
Cyl
Cylinder(s)
D
D
Dark
DAB
Delayed Accessory Bus
dB
Decibels
dBA
Decibels on A-weighted Scale
DC
Direct Current, Duty Cycle
DCM
Door Control Module
DE
Drive End
DEC
Digital Electronic Controller
DERM
Diagnostic Energy Reserve Module
DI
Distributor Ignition
dia
Diameter
DIC
Driver Information Center
Diff
Differential
DIM
Dash Integration Module
DK
Dark
DLC
Data Link Connector
DMCM
Drive Motor Control Module
DMM
Digital Multimeter
DMSDS
Drive Motor Speed and Direction Sensor
DMU
Drive Motor Unit
DOHC
Dual Overhead Camshafts
DPM
Driver Position Module
DR, Drvr
Driver
DRL
Daytime Running Lamps
DSCC
Distance Sensing Cruise Control
DTC
Diagnostic Trouble Code
E
EBCM
Electronic Brake Control Module
EBTCM
Electronic Brake and Traction Control Module
EC
Electrical Center, Engine Control
ECC
Electronic Climate Control
ECI
Extended Compressor at Idle
ECL
Engine Coolant Level
ECM
Engine Control Module, Electronic Control Module
ECS
Emission Control System
ECT
Engine Coolant Temperature
EEPROM
Electrically Erasable Programmable Read Only Memory
EEVIR
Evaporator Equalized Values in Receiver
EFE
Early Fuel Evaporation
EGR
Exhaust Gas Recirculation
EGR TVV
Exhaust Gas Recirculation Thermal Vacuum Valve
EHPS
Electro-Hydraulic Power Steering
EI
Electronic Ignition
ELAP
Elapsed
ELC
Electronic Level Control
E/M
English/Metric
EMF
Electromotive Force
EMI
Electromagnetic Interference
Eng
Engine
EOP
Engine Oil Pressure
EOT
Engine Oil Temperature
EPA
Environmental Protection Agency
EPR
Exhaust Pressure Regulator
EPROM
ESB
Expansion Spring Brake
ESC
Electronic Suspension Control
ESD
Electrostatic Discharge
ESN
Electronic Serial Number
ETC
Electronic Throttle Control, Electronic Temperature Control, Electronic Timing Control
ETCC
Electronic Touch Climate Control
ETR
Electronically Tuned Receiver
ETS
Enhanced Traction System
EVAP
Evaporative Emission
EVO
Electronic Variable Orifice
Exh
Exhaust
F
°F
Degrees Fahrenheit
FC
Fan Control
FDC
Fuel Data Center
FED
Federal All United States except California
FEDS
Fuel Enable Data Stream
FEX
Front Exchanger
FF
Flexible Fuel
FFH
Fuel-Fired Heater
FI
Fuel Injection
FMVSS
Federal U.S. Motor Vehicle Safety Standards
FP
Fuel Pump
ft
Foot/Feet
FT
Fuel Trim
F4WD
Full Time Four Wheel Drive
4WAL
Four Wheel Antilock
4WD
Four Wheel Drive
FW
Flat Wire
FWD
Front Wheel Drive, Forward
G
g
Grams, Gravitational Acceleration
GA
Gage, Gauge
gal
Gallon
gas
Gasoline
GCW
Gross Combination Weight
GD
Gold
Gen
Generator
GL
Gear Lubricant
GM
General Motors
GM SPO
General Motors Service Parts Operations
GN
Green
gnd
Ground
gpm
Gallons per Minute
GRN
Green
GRY
Gray
GVWR
Gross Vehicle Weight Rating
GY
Gray
H
H
Hydrogen
H2O
Water
Harn
Harness
HC
Hydrocarbons
HCM
HVAC Control Module
H/CMPR
High Compression
HD
Heavy Duty
HDC
Heavy Duty Cooling
hex
Hexagon, Hexadecimal
Hg
Mercury
Hi Alt
High Altitude
HO2S
Heated Oxygen Sensor
hp
Horsepower
HPL
High Pressure Liquid
HPS
High Performance System
HPV
High Pressure Vapor
HPVS
Heat Pump Ventilation System
Htd
Heated
HTR
Heater
HUD
Head Up Display
HVAC
Heater Ventilation Air Conditioning
HVACM
Heater Vent Air Conditioning Module
HVIL
High Voltage Interlock Loop
HVM
Heater Vent Module
Hz
Hertz
I
IAC
Idle Air Control
IAT
Intake Air Temperature
IC
Integrated Circuit, Ignition Control
ICCS
Integrated Chassis Control System
ICM
Ignition Control Module
ID
Identification, Inside Diameter
IDI
Integrated Direct Ignition
IGBT
Insulated Gate Bi-Polar Transistor
ign
Ignition
ILC
Idle Load Compensator
in
Inch/Inches
INJ
Injection
inst
Instantaneous, Instant
IP
Instrument Panel
IPC
Instrument Panel Cluster
IPM
Instrument Panel Module
I/PEC
Instrument Panel Electrical Center
ISC
Idle Speed Control
ISO
International Standards Organization
ISS
Input Speed Shaft, Input Shaft Speed
ITCM
Integrated Transmission Control Module
K
KAM
Keep Alive Memory
KDD
Keyboard Display Driver
kg
Kilogram
kHz
Kilohertz
km
Kilometer
km/h
Kilometers per Hour
km/l
Kilometers per Liter
kPa
Kilopascals
KS
Knock Sensor
kV
Kilovolts
L
L
Light
L
Liter
L4
Four Cylinder Engine, In-Line
L6
Six-Cylinder Engine, In-Line
lb
Pound
lb ft
Pound Feet Torque
lb in
Pound Inch Torque
LCD
Liquid Crystal Display
LDCL
Left Door Closed Locking
LDCM
Left Door Control Module
LDM
Lamp Driver Module
LED
Light Emitting Diode
LEV
Low Emissions Vehicle
LF
Left Front
lm
Lumens
LR
Left Rear
LT
Left
LT
Light
LT
Long Term
LTPI
Low Tire Pressure Indicator
LTPWS
Low Tire Pressure Warning System
LWB
Long Wheel Base
M
MAF
Mass Air Flow
Man
Manual
MAP
Manifold Absolute Pressure
MAT
Manifold Absolute Temperature
max
Maximum
M/C
Mixture Control
MDP
Manifold Differential Pressure
MFI
Multiport Fuel Injection
mi
Miles
MIL
Malfunction Indicator Lamp
min
Minimum
MIN
Mobile Identification Number
mL
Milliliter
mm
Millimeter
mpg
Miles per Gallon
mph
Miles per Hour
ms
Millisecond
MST
Manifold Surface Temperature
MSVA
Magnetic Steering Variable Assist, Magnasteer®
M/T
Manual Transmission/Transaxle
MV
Megavolt
mV
Millivolt
N
NA
Natural
NAES
North American Export Sales
NC
Normally Closed
NEG
Negative
Neu
Neutral
NI
Neutral Idle
NiMH
Nickel Metal Hydride
NLGI
National Lubricating Grease Institute
N·m
Newton-meter Torque
NO
Normally Open
NOx
Oxides of Nitrogen
NPTC
National Pipe Thread Coarse
NPTF
National Pipe Thread Fine
NOVRAM
Non-Volatile Random Access Memory
O
O2
Oxygen
O2S
Oxygen Sensor
OBD
On-Board Diagnostics
OBD II
On-Board Diagnostics Second Generation
OC
Oxidation Converter Catalytic
OCS
Opportunity Charge Station
OD
Outside Diameter
ODM
Output Drive Module
ODO
Odometer
OE
Original Equipment
OEM
Original Equipment Manufacturer
OG
Orange
OHC
Overhead Camshaft
Ω
Ohm
OL
Open Loop, Out of Limits
ORC
Oxidation Reduction Converter Catalytic
ORN
Orange
ORVR
On-Board Refueling Vapor Recovery
OSS
Output Shaft Speed
oz
Ounce(s)
P
PAG
Polyalkylene Glycol
PAIR
Pulsed Secondary Air Injection
PASS, PSGR
Passenger
PASS-Key®
Personalized Automotive Security System
P/B
Power Brakes
PC
Pressure Control
PCB
Printed Circuit Board
PCM
Powertrain Control Module
PCS
Pressure Control Solenoid
PCV
Positive Crankcase Ventilation
PEB
Power Electronics Bay
PID
Parameter Identification
PIM
Power Inverter Module
PK
Pink
PM
Permanent Magnet Generator
P/N
Part Number
PNK
Pink
PNP
Park/Neutral Position
PRNDL
Park, Reverse, Neutral, Drive, Low
POA
Pilot Operated Absolute Valve
POS
Positive, Position
POT
Potentiometer Variable Resistor
PPL
Purple
ppm
Parts per Million
PROM
P/S, PS
Power Steering
PSCM
Power Steering Control Module, Passenger Seat Control Module
PSD
Power Sliding Door
PSP
Power Steering Pressure
psi
Pounds per Square Inch
psia
Pounds per Square Inch Absolute
psig
Pounds per Square Inch Gauge
pt
Pint
PTC
Positive Temperature Coefficient
PU
Purple
PWM
Pulse Width Modulated
Q
QDM
Quad Driver Module
qt
Quart(s)
R
R-12
Refrigerant-12
R-134a
Refrigerant-134a
RAM
Random Access Memory, Non-permanent memory device, memory contents are lost when power is removed.
RAP
Retained Accessory Power
RAV
Remote Activation Verification
RCDLR
Remote Control Door Lock Receiver
RD
Red
RDCM
Right Door Control Module
Ref
Reference
Rev
Reverse
REX
Rear Exchanger
RIM
Rear Integration Module
RF
Right Front, Radio Frequency
RFA
Remote Function Actuation
RFI
Radio Frequency Interference
RH
Right Hand
RKE
Remote Keyless Entry
Rly
Relay
ROM
Read Only Memory, Permanent memory device, memory contents are retained when power is removed.
RPM
Revolutions per Minute Engine Speed
RPO
Regular Production Option
RR
Right Rear
RSS
RTD
Real Time Damping
RT
Right
RTV
Room Temperature Vulcanizing Sealer
RU
Rust
RWAL
Rear Wheel Antilock
RWD
Rear Wheel Drive
S
s
Second(s)
SAE
Society of Automotive Engineers
SC
Supercharger
SCB
Supercharger Bypass
SCM
Seat Control Module
SDM
Sensing and Diagnostic Module
SEO
Special Equipment Option
SFI
Sequential Multiport Fuel Injection
SI
System International Modern Version of Metric System
SIAB
Side Impact Air Bag
SIR
Supplemental Inflatable Restraint
SLA
Short/Long Arm Suspension
sol
Solenoid
SO2
Sulfur Dioxide
SP
Splice Pack
S/P
Series/Parallel
SPO
SPS
Service Programming System, Speed Signal
sq ft, ft²
Square Foot/Feet
sq in, in²
Square Inch/Inches
SR
Silver
SRC
Service Ride Control
SRI
Service Reminder Indicator
SRS
Supplemental Restraint System
SS
Shift Solenoid
ST
Scan Tool
STID
Station Identification Station ID
S4WD
Selectable Four-Wheel Drive
Sw
Switch
SWB
Short Wheel Base
SWPS
Steering Wheel Position Sensor
syn
Synchronizer
T
TAC
Throttle Actuator Control
Tach
Tachometer
TAP
Transmission Adaptive Pressure, Throttle Adaptive Pressure
TBI
Throttle Body Fuel Injection
TC
Turbocharger, Transmission Control
TCC
Torque Converter Clutch
TCS
Traction Control System
TDC
Top Dead Center
TEMP
Temperature
Term
Terminal
TFP
Transmission Fluid Pressure
TFT
Transmission Fluid Temperature
THM
Turbo Hydro-Matic
TIM
Tire Inflation Monitoring, Tire Inflation Module
TL
Teal
TN
Tan
TOC
Transmission Oil Cooler
TP
Throttle Position
TPA
Terminal Positive Assurance
TPM
Tire Pressure Monitoring, Tire Pressure Monitor
TQ
Turquoise
TR
Transmission Range
TRANS
TT
Tell Tail Warning Lamp
TV
Throttle Valve
TVRS
Television and Radio Suppression
TVV
TWC
Three Way Converter Catalytic
TWC+OC
Three Way + Oxidation Converter Catalytic
TXV
Thermal Expansion Valve
U
UART
Universal Asynchronous Receiver Transmitter
U/H
Underhood
U/HEC
Underhood Electrical Center
U-joint
Universal Joint
UTD
Universal Theft Deterrent
UV
Ultraviolet
V
V
Volt(s), Voltage
V6
Six-Cylinder Engine, V-Type
V8
Eight-Cylinder Engine, V-Type
Vac
Vacuum
VAC
Vehicle Access Code
VATS
Vehicle Anti-Theft System
VCIM
Vehicle Communication Interface Mode
VCM
Vehicle Control Module
V dif
Voltage Difference
VDOT
Variable Displacement Orifice Tube
VDV
Vacuum Delay Valve
vel
Velocity
VES
Variable Effort Steering
VF
Vacuum Fluorescent
VIO
Violet
VIN
Vehicle Identification Number
VLR
Voltage Loop Reserve
VMV
Vacuum Modulator Valve
VR
Voltage Regulator
V ref
Voltage Reference
VSES
Vehicle Stability Enhancement System
VSS
Vehicle Speed Sensor
VT
Violet
W
w/
With
W/B
Wheel Base
WH
White
WHL
Wheel
WHT
White
w/o
Without
WOT
Wide Open Throttle
W/P
Water Pump
W/S
Windshield
WSS
Wheel Speed Sensor
WU-OC
Warm Up Oxidation Converter Catalytic
WU-TWC
Warm Up Three-Way Converter Catalytic
X
X-valve
Expansion Valve
Y
yd
Yard(s)
YE
Yellow
YEL
Yellow
A
A
Ampere(s)
ABS
A/C
Air Conditioning
AC
Alternating Current
ACC
ACL
Air Cleaner
ACM
ACR4
AD
A/D
Analog to Digital
ADL
Automatic Door Lock
A/F
Air/Fuel Ratio
AH
Active Handling
AIR
ALC
AM/FM
Ant
Antenna
AP
Accelerator Pedal
APCM
API
APP
APT
ASM
ASR
A/T
ATC
ATDC
ATSLC
Auto
Automatic
avg
Average
A4WD
AWG
American Wire Gage
B
B+
BARO
Barometric Pressure
BATT
Battery
BBV
BCA
BCM
Body Control Module
BG
Beige
BHP
Brake Horsepower
BK
Black
BLK
Black
BLU
Blue
BN
Brown
BP
Back Pressure
BPCM
BPMV
BPP
BRN
Brown
BTDC
BTM
BTSI
Btu
BU
Blue
C
°C
Degrees Celsius
CAC
Charge Air Cooler
CAFE
Cal
Calibration
Cam
Camshaft
CARB
CC
Coast Clutch
cm³
Cubic Centimeters
CCM
CCOT
CCP
CD
Compact Disc
CE
Commutator End
CEAB
CEMF
CEX
Cabin Exchanger
cfm
cg
Center of Gravity
CID
CKP
Crankshaft Position
CKT
Circuit
C/Ltr
Cigar Lighter
CL
Clear
CL
Closed Loop
CLS
CMC
CMP
Camshaft Position
CNG
CO
Carbon Monoxide
CO2
Carbon Dioxide
Coax
Coaxial
COMM
Communication
Conn
Connector
CPA
CPP
CPS
CPU
CR
Cream
CRT
Cathode Ray Tube
CRTC
CS
Charging System
CSFI
CTP
cu ft
Cubic Foot/Feet
cu in
Cubic Inch/Inches
CV
CVRSS
Cyl
Cylinder(s)
D
D
Dark
DAB
dB
Decibels
dBA
DC
DCM
Door Control Module
DE
Drive End
DEC
DERM
DI
dia
Diameter
DIC
Diff
Differential
DIM
DK
Dark
DLC
Data Link Connector
DMCM
DMM
Digital Multimeter
DMSDS
DMU
Drive Motor Unit
DOHC
DPM
DR, Drvr
Driver
DRL
DSCC
DTC
E
EBCM
EBTCM
EC
ECC
ECI
ECL
ECM
ECS
ECT
EEPROM
EEVIR
EFE
EGR
EGR TVV
EHPS
EI
Electronic Ignition
ELAP
Elapsed
ELC
E/M
English/Metric
EMF
Electromotive Force
EMI
Eng
Engine
EOP
Engine Oil Pressure
EOT
EPA
EPR
EPROM
ESB
ESC
ESD
ESN
ETC
ETCC
ETR
ETS
EVAP
EVO
Exh
Exhaust
F
°F
Degrees Fahrenheit
FC
Fan Control
FDC
Fuel Data Center
FED
FEDS
FEX
Front Exchanger
FF
Flexible Fuel
FFH
Fuel-Fired Heater
FI
Fuel Injection
FMVSS
FP
Fuel Pump
ft
Foot/Feet
FT
Fuel Trim
F4WD
4WAL
Four Wheel Antilock
4WD
Four Wheel Drive
FW
Flat Wire
FWD
G
g
GA
Gage, Gauge
gal
Gallon
gas
Gasoline
GCW
GD
Gold
Gen
Generator
GL
Gear Lubricant
GM
General Motors
GM SPO
GN
Green
gnd
Ground
gpm
Gallons per Minute
GRN
Green
GRY
Gray
GVWR
GY
Gray
H
H
Hydrogen
H2O
Water
Harn
Harness
HC
Hydrocarbons
HCM
HVAC Control Module
H/CMPR
High Compression
HD
Heavy Duty
HDC
Heavy Duty Cooling
hex
Hg
Mercury
Hi Alt
High Altitude
HO2S
hp
Horsepower
HPL
HPS
HPV
High Pressure Vapor
HPVS
Htd
Heated
HTR
Heater
HUD
Head Up Display
HVAC
HVACM
HVIL
HVM
Heater Vent Module
Hz
Hertz
I
IAC
Idle Air Control
IAT
IC
ICCS
ICM
ID
IDI
IGBT
ign
Ignition
ILC
in
Inch/Inches
INJ
Injection
inst
IP
Instrument Panel
IPC
IPM
I/PEC
ISC
Idle Speed Control
ISO
ISS
ITCM
K
KAM
Keep Alive Memory
KDD
kg
Kilogram
kHz
Kilohertz
km
Kilometer
km/h
Kilometers per Hour
km/l
kPa
Kilopascals
KS
Knock Sensor
kV
Kilovolts
L
L
Light
L
Liter
L4
L6
lb
Pound
lb ft
Pound Feet Torque
lb in
Pound Inch Torque
LCD
LDCL
LDCM
LDM
Lamp Driver Module
LED
LEV
LF
Left Front
lm
Lumens
LR
Left Rear
LT
Left
LT
Light
LT
Long Term
LTPI
LTPWS
LWB
Long Wheel Base
M
MAF
Mass Air Flow
Man
Manual
MAP
MAT
max
Maximum
M/C
Mixture Control
MDP
MFI
mi
Miles
MIL
min
Minimum
MIN
mL
Milliliter
mm
Millimeter
mpg
Miles per Gallon
mph
Miles per Hour
ms
Millisecond
MST
MSVA
M/T
MV
Megavolt
mV
Millivolt
N
NA
Natural
NAES
NC
Normally Closed
NEG
Negative
Neu
Neutral
NI
Neutral Idle
NiMH
NLGI
N·m
Newton-meter Torque
NO
Normally Open
NOx
Oxides of Nitrogen
NPTC
NPTF
NOVRAM
O
O2
Oxygen
O2S
Oxygen Sensor
OBD
OBD II
OC
OCS
OD
Outside Diameter
ODM
Output Drive Module
ODO
Odometer
OE
Original Equipment
OEM
OG
Orange
OHC
Overhead Camshaft
Ω
Ohm
OL
ORC
ORN
Orange
ORVR
OSS
Output Shaft Speed
oz
Ounce(s)
P
PAG
Polyalkylene Glycol
PAIR
PASS, PSGR
Passenger
PASS-Key®
P/B
Power Brakes
PC
Pressure Control
PCB
PCM
PCS
PCV
PEB
PID
PIM
PK
Pink
PM
P/N
Part Number
PNK
Pink
PNP
PRNDL
POA
POS
Positive, Position
POT
PPL
Purple
ppm
Parts per Million
PROM
P/S, PS
Power Steering
PSCM
PSD
Power Sliding Door
PSP
psi
psia
psig
pt
Pint
PTC
PU
Purple
PWM
Q
QDM
Quad Driver Module
qt
Quart(s)
R
R-12
Refrigerant-12
R-134a
Refrigerant-134a
RAM
RAP
RAV
RCDLR
RD
Red
RDCM
Ref
Reference
Rev
Reverse
REX
Rear Exchanger
RIM
RF
RFA
RFI
RH
Right Hand
RKE
Rly
Relay
ROM
RPM
RPO
RR
Right Rear
RSS
RTD
Real Time Damping
RT
Right
RTV
RU
Rust
RWAL
Rear Wheel Antilock
RWD
Rear Wheel Drive
S
s
Second(s)
SAE
SC
Supercharger
SCB
Supercharger Bypass
SCM
Seat Control Module
SDM
SEO
SFI
SI
SIAB
Side Impact Air Bag
SIR
SLA
sol
Solenoid
SO2
Sulfur Dioxide
SP
Splice Pack
S/P
Series/Parallel
SPO
SPS
sq ft, ft²
Square Foot/Feet
sq in, in²
Square Inch/Inches
SR
Silver
SRC
SRI
SRS
SS
Shift Solenoid
ST
Scan Tool
STID
S4WD
Sw
Switch
SWB
Short Wheel Base
SWPS
syn
Synchronizer
T
TAC
Tach
Tachometer
TAP
TBI
TC
TCC
TCS
TDC
Top Dead Center
TEMP
Temperature
Term
Terminal
TFP
TFT
THM
Turbo Hydro-Matic
TIM
TL
Teal
TN
Tan
TOC
TP
Throttle Position
TPA
TPM
TQ
Turquoise
TR
Transmission Range
TRANS
TT
TV
Throttle Valve
TVRS
TVV
TWC
TWC+OC
TXV
U
UART
U/H
Underhood
U/HEC
U-joint
Universal Joint
UTD
UV
Ultraviolet
V
V
Volt(s), Voltage
V6
V8
Vac
Vacuum
VAC
Vehicle Access Code
VATS
VCIM
VCM
V dif
Voltage Difference
VDOT
VDV
Vacuum Delay Valve
vel
Velocity
VES
VF
Vacuum Fluorescent
VIO
Violet
VIN
VLR
VMV
VR
Voltage Regulator
V ref
Voltage Reference
VSES
VSS
VT
Violet
W
w/
With
W/B
Wheel Base
WH
White
WHL
Wheel
WHT
White
w/o
Without
WOT
Wide Open Throttle
W/P
Water Pump
W/S
Windshield
WSS
Wheel Speed Sensor
WU-OC
WU-TWC
X
X-valve
Expansion Valve
Y
yd
Yard(s)
YE
Yellow
YEL
Yellow
Dan_the_C5_Man (09-22-2016)
Thanks erick_e - looks like my guesses were correct.. Why they didn't place the abbreviations for the wire colors in the wiring section is beyond me.
Received 8,926 Likes
D-BU = Dark Blue ??
BN = Brown ??
TN = Tan ??
Thanks in advance!
D-BU = Dark Blue ??
BN = Brown ??
TN = Tan ??
Thanks in advance!
Bill
