[Z06] Mamo Motorsports Build: MMS Heads, Solid Roller, MSD, Factory Shortblock
#281
Shouldn't be long now until installation.
Regards,
Josh
#282
Thanks Josh! Can't wait to see it all come together.
Race on!
Race on!
#283
Another race car part. In preparation for my 1/2 mile race at Ocala coming up I bought an MSD 2-Step from Summit tonight on sale. Looks like a clean install, very important to me. The only wire ran into my cabin through the firewall grommet is the harness for the wideband. Hoping to tap the clutch switch at the ECM harness as cleanly as possible.
Does anyone have one of these on their car that they can give some feedback on? Thanks.
You may have to run a relay with this two step depending on the year of your car. My 07 required it, but I never actually installed it all. Read the lingefelter instructions for more info.
I don't think I've seen someone use a two for half mile. Isn't this kind of unusual?
The reason I didn't install mine is because I slip my clutch a lot at the track and as soon as that bottom clutch switch loses contact the rpms are going to shoot up. I figured just flooring the car myself would do the same thing so I've been doing that and have gotten excellent 60ft times. I do think this would help a little with consistency but not a ton, especially as your clutch wears and engages further and further avove the floor.
#284
Hey Scott, I'll definitely take some high resolution pictures of the installation. From our correspondence I know you like details! My 2" ARH headers are the part number for the ZR1, hopefully ARH designed them to sufficiently clear the ZR1 Oil Cooler. The LG's interfered about 1/8" and I had to grind on the casting of the oil cooler for clearance, which was unfortunate to do on a 300 dollar brand new oil cooler. The LG's also interfered a touch with the factory oil cooler lines, I emailed LG about this issue and didn't receive a response. It wasn't the end of the world, I just had to remove the lines and bend them on the workbench. They are steel, and are HARD to bend, you are superman if you can bend them while they are still bolted to the oil pan.
Regards,
Josh
Regards,
Josh
Is there any downside of running the zr1 part number? If not, I don't understand why they would have two different pns.
#286
You may have to run a rely with this two step depending on the year of your car. My 07 required it, but I never actually installed it all. Read the lingefelter instructions for more info.
#287
I installed an MSD 2-step on a customer's car this morning, a 2007 C6Z. We soldered a lead to the gray wire on pin #6 of the C1 Harness for the CPP switch signal. This is a grounded signal, so we used the grounded activation input to the MSD box. Works perfect
#288
That's precisely why....fitiment issues started showing up on 2011+ C6Z's with a few different header brands because the ZR1 oil cooler was carried over to the Z06 that year.
#289
You only need to give light throttle to get the revs up to bounce off the limiter, then release the clutch as slow or as fast as you want, while giving as much or as little throttle as you want. You have full control of the launch.
The best part is... finding your launch Rpm at the starting line is one less thing to think about when preparing for lift-off....
Josh, very nice build btw!!!
#290
I've run a 2-Step for years and they are great for maintaining consistency and adjusting your launch according to track conditions.
That is great advice regarding the amount of throttle needed to activate the 2-step. I have three launches with the system now and I was WOT during each of them. I was very consistent. When I get my personal car running again I will test and tune for the best possible launches on given track conditions. One thing is certain, 2-steps sound awesome, and holding an rpm is one less thing to concentrate one like you already wrote. My friends car with HCI, solid roller, RHS block, 3.90 gears, M/T DR's wanted about 3300 rpm on the 2-step with very little clutch slip. With more passes I would have increased rpm and added a bit more slip to get rid of a slight bog. 1.7 60' times.
I'm thinking that my personal car with 3.42 gears will want around 4000rpm and clutch slip for the first 5-10 feet given similar track conditions. The 3.90 gears really didn't need much rpm to get wheel spin. 3500 and it spun, but 60' didn't change.
The 2-step really adds a new level of launch control for sure. It is sort of a tool to help figure out what works and what doesn't. Awesome product.
#291
Here is a slow-mo video of the 3500 rpm launch. Yours truly in the pilot seat, I rebuilt the valvetrain on this customer's car with PAC springs/components spec'd supplied by Tony. I really dig the slooooooow pop pop pop of the slow motion 2-Step.
#294
St. Jude Donor '13
"How I think I drive"
https://youtu.be/VAOxhpEAkQo
....."How I really drive" <insert regular shifting video>
Great videos! Loved the slo-mo then real speed of the launch. Really shows how you can set up the two-step to get you right at the verge of tire slippage but not excessive. Nice driving!
#295
Ported Dry Sump Oil Passages
Per Katech recommendation, I port matched the oil passages of the LS7 oil pan to the same size as the passages on the Katech Red oil pump.
Dremel and some sand rolls.
#299
I was running 345/30-19 Michelin Pilot Super Spinners. Brought a knife to a gun fight
Video:
#300
Last year I ran 162.94 mph in 4th gear, turning between 6800-7000 rpm. It was tached out, but I couldn't see exactly!
Video:
https://youtu.be/AfIA76q_HvA
Video:
A taller tire so you can keep it in 4th longer and maybe a ZR1 box with the .82 5th gear with the thought you will run right through 4th at the new power level and will need 5th.
