[Z06] Broken Clutch Pedal Spring
I know this has been covered in the past and is why I knew what was going on last week when my clutch pedal was making a metallic sound when returning to upright position. Then the sound stopped. Today I found this on the floor below the pedal. Clutch seems to be working fine. My knee is a little screwed up from tennis so I may not be able to notice the difference in function. I have warranty so will get if fixed soon.
DH
DH
Actually it is a dual purpose spring and also helps to return the clutch pedal to the full up position. Since you still have a warranty, I've heard that GM may deny a warranty claim if you don't have this spring installed and your clutch goes out.
DH
Mine just broke at 29k miles. $9 and 5 min of work and it's as good as new.
To put it in, put each side in first and then swing the spring up out of the way. Then put the pedal on the floor and simply swing spring down into place. Takes two seconds after you've done it once.
Also, I've seen the document from gm saying this is a dual purpose spring but after replacing it and checking things out I'm quite confident it only assists the pedal in the down position. I'm stumped why they say that. It seems like risk they mention would be higher WITH the spring. Anyone have more info on this? Lots of conflicting opinions out there.
Supporting Vendor
Received 1,012 Likes
The spring is also there to keep GM warranty's down from those that may "ride" the clutch. As noted above removing the spring removes the free play (so to speak) and touching the clutch in any way results in fluid movement resulting in mechanical movement of the clutch pack.
http://www.americanheritageperformance.com/
racerx3317 (10-25-2016)
