[Z06] N/A High Compression and Meth
Interested in hearing about setups with results and track times. Planning on upgrades this winter and looking at possible paths to go. Did some searching and reading through old threads, but would like to get more recent info.
you will loose a little power without tuning for meth. AND tuning for meth gets tricky. But if you are ok loosing a little---then it definitely helps with pre ignition/knock
Goals are at least 600hp and 550tq. I'm currently at 550/500 through a stalled auto (4l65).
OR.....
Use distilled water with only 10%meth or so to lower the surface tension of pure water to atomize the spray better.
This way you do not need to tune for AFR and can use the spray as an octane booster.
Works extremely well and technically water is infinite octane...
