[Z06] Forgestar F14 in 17" drag pack package
#41
At the moment, they just have front fitments and I really don't see anything for the rears unless these 15x10 +44 fit over the rear brakes which I feel like they do. Going to have to double check with the rotor sizes and so forth.
The difference I visually see is that the Drag wheels have two valve stem holes and knurling on the bead seats on just the front side of the wheels.
Rotor Diameters/Thicknesses:
Base: F 325mm/R 305mm
Z51: F 340mm/R 330mm
Z06: F 355mm/R 340mm
ZR1: R 394mm/R 380mm
All (3) variants Rotor thickness (with exception of ZR1): F 32mm/R 26mm
I doubt a 15" wheel would fit without using drag spindles. The control arm would most likely rub. 17x10.5 is probably the best size for guys looking to run a 26" drag radial/slick
#42
Received 2,060 Likes
For reference, the GTO spare wheel 17 x 4 IIRC @ 12# will clear front base brakes, but not any larger ones without adapters. M&H makes tires for this size. If you are a serious racer, swapping to base (JL9) brakes will save you a bunch more reciprocating weight.
C5Z06 fronts 17 x 9.5 @ 19# and several C4 wheels of the same size, but slightly heavier, will work well on all but ZR1 rears. The slightly narrower wheel also allows a little more sidewall flex upon launch.
#45
They are making a specific z06 fitment that should be coming out in a month. 17x5 and 17x 11. Apparently no spacers needed too. I was told the colors will either be gunmetal or flat black. They are also making unfinished wheels so you can get them powder coated any color.
I will be ordering myself a set too.
#46
if any of u are on Instagram u can look up "missriss_z06" and see her rear f14 17" setup.... not bad looking imo....I'll try and get the pic over here for u guys
#48
yes ur correct....I hadn't really been keeping up with the thread so I didn't know if ppl were just wondering about the 17" in the rear cuz last I read they didn't have the actual drag pack 17" to fit the Zs yet
#50
Uh...the drag wheel isn't an option for us in 17". That's been made pretty clear in this thread.
#52
i have searched but haven't come across any pics. the only pic ive seen on a z is a 17 on the rear and an 18 on the front.
ill post pics once i get mine. probably 4-5 weeks out.
#54
Tons of forgestar reviews out there. Not sure anything would be different from the other sizes. This is just a new size for drag.
They are ok wheels, not amazing, not bad. Decent for the price. I'm still waiting on Cayle to get me a price on 15x10 in black for my rears to get rid of my 18" F14s and go full time 15.
#55
