[Z06] Blue smoke on overrun decel
Guys
I'm getting some blue smoke on high rpm decel, could it be caused by a catchcan??
Heads/msd/cai/arh headers no cats and btr 3 cam, we recently installed the catch can and didn't notice the smoke before
Any help appreciated
Cheers
Matt
Cheers
Matt
I have a catch can and don't have this problem. Have your shop inspect the PCV and make sure catch can is routed properly. Check for clogs.
Frequently something like this would be attributed to piston rings, but lets hope it is an issue with the new catch can. I did not have any issues like that when I installed the catch can on my 09Z several years ago, and many performance events since that time.
My catch can gets noting on highway/city driving and about 4 oz. in a HPDE day running in the 4-7K rpm range, but no blue smoke. Now with HCI I do get black smoke due to the rich tune.
Max G’s
Make sure the catch can does not route back into your intake. When you catch can gets full it will route back into the intake when you excel and the vaccum pressure increases.
Location: Virginia Beach, VA & Port Charlotte, FL (snowbird)
Received 1,095 Likes
Guides and seals can cause it, big time. I'd do a wiggle test just to be sure. You're liable to be blowing chunks of pistons out the tail pipe instead of blue smoke in the future.
Bad piston rings typically smoke on accel, not decel.
Sorry I got the wrong symptom, OP. Thanks, Undy.
Ok so i have just checked
My catch Can was set up as follows
Left side pipe was from valve covers and he right side went to valley cover
Both my intake and throttle body were plugged so I have no pcv valve
Max G’s
Supporting Vendor
trying to follow up here;
if you do not have a crankcase connection to the intake manifold (through a catch can or not) then it is impossible for the oil to be crankcase ventilation / pcv related.
on ls7's it is often down from the valves however it could certainly be coming up from around the pistons. both situations would be exaggerated by engine braking. let your brakes do the braking and let your engine do the pushing
if you think the catch can caused it, why not try putting it back the way it was before and look for a difference (sorry if this was covered) the catch can certainly has the possibility of altering pcv flow, especially if it is not installed per the mfg. routing.
Thanks mate.
I have run it with / without and on a new set up which is basically as per the drawing above. It smokes slightly on all.
I have just done a compression test and all were 220/230
The diagram you show (blue lines) and the way I installed my EE catch can is the CC inlet was from the valley cover and the outlet was to the intake manifold. You just remove the OEM U-shaped hose from the PCV system and replace it with the hoses in/out of the catch can.
It is the operator's responsibility to empty the can before it gets full. I get essentially nothing on the highway and just have to empty it after each track day, never overflowed yet.
