C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Pulsating vibration on highway?? HELP
Old 11-13-2016, 07:02 PM
tdeweese
tdeweese's Avatar
Default Pulsating vibration on highway?? HELP
Guys anyone ever had a pulsating vibration at highway speeds over 70mph? The vibration comes and goes and cyclical the pulses get closer together as you speed up. This occurred every since I removed my motor and drive line to rebuild the motor and send my transmission and diff off to RPM for complete rebuilds. I don't think its my tires/wheels as I have (2) sets and the problem shows up with both, but a little less with my drag radials. Any help greatly appreciated, driving me CRAZY!!!
Old 11-13-2016, 10:03 PM
Tech
Tech's Avatar
I have a similar vibration. I had the front tires balanced 3 times. I ultimately just replaced the wheels and tires again and the vibration is mostly gone. There are still some circumstances where I feel it but it's very light and someone else driving the car probably wouldn't notice it.
Old 11-13-2016, 11:43 PM
barneyz06
barneyz06's Avatar
If we ever figure this one out, I'd be curious. Have this too. Tried different tires, different wheels, still there. Mystery!?
Old 11-14-2016, 12:39 AM
Javvy
Javvy's Avatar
Mine disappeared when I changed tyres.
Old 11-14-2016, 12:50 AM
ltsr
6th Gear
ltsr's Avatar
Try removing your drive shaft and having it rebalanced.
Old 11-14-2016, 09:36 AM
Kenny94945
Kenny94945's Avatar
Pulsing....could the vibration also be caused by a broken/ worn/ loose motor or trans mount?
Misfire?
Please let us know what the cause was once found.
Old 11-14-2016, 11:59 AM
tdeweese
tdeweese's Avatar
Misfire?
I have come to grips that this will be a process and one I will figure out. I will post what was done to correct the issue.
Old 11-14-2016, 01:06 PM
njk4o5
njk4o5's Avatar
mine does this too. freaked me out on the highway going home the day I bought it. but its been like that for the last 25k miles. and I still have the stock front tires with 48k on them. but they are ready for replacement
Old 11-14-2016, 05:56 PM
dmuellenberg
dmuellenberg's Avatar
Wow - 48k out of the stock GY's - that must be some kind of record. You must not do very much aggressive driving (at least cornering) as the stock GY's are pretty worthless after 10k.
Old 11-14-2016, 06:06 PM
njk4o5
njk4o5's Avatar
yeah I only like to go fast in a straight line haha
Old 11-16-2016, 12:16 PM
dkz
dkz's Avatar
I started getting this when i got new tires. Mine pulses from one hand to the other at 50-55mph-ish and 70-80mph. I had the wheels balanced twice and the vibration would return after each HPDE. Maybe the tires are rotating on the wheels? I'm going to the track later this week and getting another balance, will mark the tire position to see if anything moves. I am running conti extreme D/W.
Old 11-16-2016, 02:23 PM
Dan_the_C5_Man
Dan_the_C5_Man's Avatar
Spinning on the rim, that's certainly a possibility. After a track day you'd be surprised how much rubber sticks to the inner barrel of the wheels. Depending on the track, you can pick up a comical amount of rubber slag. This stuff has to be pried off, it won't fall off on its own. And don't forget the rubber chunks that get stuck to the outside of the tires as well - it can take a while to scrub off with street driving.
Old 11-16-2016, 07:47 PM
AzDave47
Support Corvetteforum!
AzDave47's Avatar
Received 4,506 Likes on 2,597 Posts
I had this happen with a set of NT-05's. After the 3rd or 4th time balancing and an alignment the cyclical pulsing went away.
Old 04-06-2017, 05:18 PM
steelstartup
2nd Gear
steelstartup's Avatar
I just bought a 2013 Grand Sport. Only 7700 miles. At speeds over 90mph it is a high frequency rumble that you can easily feel in your seat (my wife could feel it in her seat too), but it comes and goes about every half second. In other words, it rumbles for half second, then stops, then rumbles, then stops. It does this continuously until I drop the speed below 90. I went all the way up to 135 and it still occurred. I can learn to live with it, as the handling and stability seem unaffected, but I would love to know the cause if it is an easy fix, and more importantly I would like to know if just ignoring it can lead to much bigger problems later. Thanks.
Old 04-07-2017, 12:39 AM
AzDave47
AzDave47's Avatar
It is a tire balance issue that sets up a harmonic that goes in and out of frequency with the chassis. I have had two sets of tires from different manufacturers that I have experienced this. On one set just a rebalance solved it, on the other it took 2-3 rebalances before it was cured. You may want to have your alignment checked too although that would only be a secondary contributor.
Old 02-07-2018, 01:39 PM
DadS
Cruising
DadS's Avatar
Have you determined the issue? Curious because my '16 Z06 is at the dealer for the third time for the same issue.
Old 02-07-2018, 01:56 PM
MTPZ06
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
Does your car have CCB's?
To Pulsating vibration on highway?? HELP
Old 02-07-2018, 02:02 PM
DadS
Cruising
DadS's Avatar
Nope
Old 02-08-2018, 12:29 PM
LS1Steve
LS1Steve's Avatar
Have one too... I think it might be the nature of the beast seeing as how so many have it.
Mine is only perceptible on highway (only in the steering wheel), and the vibe pulses every 2 seconds or so. Very subtle, and with aftermarket exhaust, someone else could drive my car and probably not notice it unless I point it out. 13K miles here, 2.5K on fresh MPSS tires, no major drivetrain work ever.
Old 02-08-2018, 11:47 PM
AzDave47
AzDave47's Avatar
My buddy is having a significant problem like this with his 2010 GS, didn't have the problem before new PSS. I had a similar problem with both NT-05s and PSS but ultimately after several attempts rebalancing got rid of it on my 09 Z.
Quick Reply: [Z06] Pulsating vibration on highway?? HELP
