[Z06] Angle milling heads?
Does anyone know how much you can reduce the combustion chamber size on LS7 heads before you need to have them angle milled? I need to knock about 8cc out of the chambers to achieve the compression ratio I'm looking for.
On my TFS castings, Tony Mamo took the heads down .054" to achieve 62cc. Then another .012" to achieve 60cc. Used with .040" HGs I got to 13:1 on my stock bottom end, piston was .005" out of the hole.
I wish I could give you some insight as to how much a stock casting LS7 head can go down. I know TFS casts a thicker deck. My stock casting LS7s were milled by WCCH, removing .030" down to 65cc.
If you want 8cc out, I'm betting you will need something like a .054" mill, if the casting will take it.
I appereciate the replies.
I plan to run the 0.040 gaskets. I'll call TSP today and get the deck thickness for their PRC castings.
Josh, did you have to angle mill or were you able to flat mill and retain the intake/header geometry?
Regardless of cam events or piston selection, PTV verification with clay is a basic engine building principle. Both methods are good to use and both have their benefits, dial indicator and clay. I assume that your question related to deck thickness.
At any rate, I had ample PTVC on my engine build, but I digress. So much depends on valve timing that the only way to know for sure is to measure which I am sure you already know. This goes without saying.
Tony Mamo discussing PTVC on LS1TECH:
While clay sounds "caveman" compared to a dial indicator, its actually just as effective and can offer some insight that a dial indicator does not.....specifically how much radial clearance you have around the valve.
You may have a country mile in depth but without also using clay to check, may not realize the valve was a blond hair away from one or both sides of the valve relief in the piston which could cause mechanical interference under operating conditions when pistons and valves are slightly moving and flexing, especially at higher RPM (ever see a valve dance and move around when viewing a video made on the Spintron....you would be afraid to get on your car if you did....LOL)
I like clay for backing up the data my dial indicator provides me with and I really like clay for seeing exactly where the valve lands in the pocket. Both are key pieces of information necessary when building any motor, but especially a high performance engine.
However (big "however" here guys), the key to using either method, which gets missed by so many rookie engine builders (and not so rookie engine builders as well), is you must use a solid lifter or a welded hydraulic (so it acts solid) when your testing piston to valve and when your degreeing the cam as well for that matter. I have a set of Crane solid roller lifters that I use specifically for all my engine mock up. I cant tell you how many people drop the ball on this using the hydraulic lifters that either came with the engine or they planned on using. The plunger collapses a bit under the load of the test spring and .068 P to V is really .018 or worse and they find out after the fact when they have tagged and bent a few valves or potentially scrapped their engine with an even uglier outcome.
Sorry to go off a bit in a slightly different direction with this reply but is all related to the same procedure and its good advice that I'm sure potentially might save some of you reading this alot of financial hardship down the road.
I used Cometic's on the old motor, they never leaked.
Quench.. Improves detonation resistance, "free" power. I thought about it when I did mine, but I went with .020 mill, knew I was keeping the stock cam, was paranoid about having to pull timing - in hindsight, I should have done it.
When I sent my heads to Texas Speed. I had them mill my LS7 OEM castings .050. I believe they said my compression would be 12:1 using OEM head gaskets.
https://thmotorsports.com/i-462064.a...G64hoCWOHw_wcB
I also don't focus on DCR. I stick with SCR. SCR is fixed, whereas dynamic can vary. I don't like being "locked" into any one particular camshaft profile. Most of my race builds that see the engine dyno will have several camshafts stabbed before I'm done. Computer based simulators are not a smart as their proponents like to make them out to be.
Supporting Vendor
Received 1,012 Likes
We can flat mill.
We can angle mill.
We offer top tier work at a very competitive price point.
We have many many many satisfied LS7 head customers all over the united states and Canada (We even have very satisfied LS7 head customers in other country's such as UAE and Germany, ect...).
http://www.americanheritageperformance.com/
310-326-2399
or
HP@americanheritageperformance.com
We rework quite a few sets every month for Forum vendors and even GM dealerships.
We can flat mill.
We can angle mill.
310-326-2399
or
We can flat mill.
We can angle mill.
310-326-2399
or
Cometics are great. They aren't quite $100/ea, they can be found for $82/ea. Very cheap horsepower, quality isn't cheap.
Dan covered why. You can actually get away with more SCR with a tight quench / squish because the chamber is more resistant to detonation with wedge chambers. That's why I target .035 - .040 for steel rods. A touch more for Aluminum rods. I'd check your piston height first, before buying gaskets. And if you are using forged pistons that have cold rock, lean towards the higher side.
