[Z06] New Lifters in Low Mileage LS7
Freshening up the heads in my 2007 LS7 with 30,000 miles. I understand it's not necessary, but is there any downside to replacing the lifters when not replacing the camshaft?
My thinking is that if you have a good proven set now? why take a chance of introducing a new failure point.
Il take proven over a guess.
I was in the same boat as you. Just had AHP do my heads and reinstalling them now. For cheap money and piece of mind, I changed them.
-Jimbo
-Jimbo
I changed mine when I did the heads at 3500 miles. If you only had to take the intake manifold off to get to them I'd probably let them slide but when you need to pull the heads I'm changing them now. I'd also replace them with something a bit better than stock and of course the trays too.
I'd feel like a fool if I did all that work and then in a few thousand miles I had a lifter turn or just fail and mess up most of my motor over 2-3 hundred bucks.
This was my thought when the heads came off for other reasons. Cheap insurance, mine was low miles as well.
http://johncalliesinc.com/morel_prod...ke=Chevy&pe=LS
CHEVY LS HYDRAULIC ROLLER LIFTERS
Set# Pair# Body D Rol lD Description Avail
4708 5912 0.842 0.750 LS .842D HYD ROLLER FOR STD & HI LIFT
FITS LS STOCK ROCKER BOXES NOW
4793 5913 0.842 0.750 LS .842D HYD ROLLER (HLT) FOR STD & HI LIFT
6504 6503 0.842 0.700 LS .842D STK REP POL BODY HYD ROLL LOCK RING AXLE
FITS LS STOCK ROCKER BOX RECOMMEND MAX CAM LIFT .360" MIN BC 1.445" NOW
5290 5289 0.842 0.700 LS .842D T/B STREET PERF HYD ROLLER; FITS 5 HBP NOW
5206 5205 0.842 0.750 LS .842D T/B HYD ROLLER; FITS 5 & 6 HBP NOW
5850 5849 0.842 0.750 LS .842D T/B (HLT) HYD ROLLER; FITS 5 & 6 HBP NOW
5294 5293 0.842 0.750 LS .842D T/B (HI RPM) O/C HYD ROLLER; FITS 5 & 6 HBP
DO NOT USE OIL HEAVIER THAN 5W40 NOW
5472 5471 0.903 0.810 LS .903D T/B (HI RPM) O/C P/O HYD ROLLER; FITS 5 & 6 HBP
I wasn't impressed with the quality of the new GM lifters I bought. No issues luckily though. Seems like more and more people are going aftermarket lately with some doing short travel or even solid. I'm going to be looking into those options more for the next time I have my heads off. I like the short travel idea, but depending on how short the travel is you might need adjustable rockers.
30,000 miles means you probably have very little to no wear. Mine looked perfect at 44k and I would have reused them had it not been a new cam, and I followed a recommendation.
As suggested, you should inspect them, if they have wear signs then yes install new.
If they are clean odds are they will outlast the rest of the motor. They are not really a wear item and yours should be by all rights still in new condition.
