C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Faulty lifter ate the camshaft
Old 12-05-2016, 05:11 PM
Synacks
Synacks's Avatar
Default Faulty lifter ate the camshaft
Guess I'm joining the not so wonderful club of bad lifters and ruined camshafts.
I've got a really good mechanic taking a look at it right now, has built hundreds of race cars and works on Chevy and LS motors all the time.
Is there anything I can relay to him that might help?
He seems to think that the whole motor and a bunch of other things will need to come out and will cost at least a few thousand $$$$ to do the job, and multiple weeks of effort.
Also, are there newer/better replacement parts out there so I can avoid having this event occurring twice?
Any help would be greatly appreciated.
Old 12-05-2016, 05:25 PM
rjacobs
rjacobs's Avatar
If there is debris in the motor, yup, motor is coming out to clean it all out. Hopefully it didnt eat bearings, crank, rods, etc...
Until you know WHAT happened, hard to recommend replacement parts that "might" be better.
Old 12-05-2016, 05:37 PM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Factory? Aftermarket? Stock cam?
All of them have seen failures. Go with a good proven setup. The new johnson lifters are nice.
Old 12-05-2016, 05:44 PM
outhouse
outhouse's Avatar
Originally Posted by Synacks
He seems to think that the whole motor.
Not enough info for anyone to help with a hunch for a diagnosis
Happens, does not mea the rest of the motor needs pulled.
What was oil pressure ???? oil pressure low, might be pulling everything.
How many mils and what year? 13? ya everythings out
Old 12-05-2016, 08:30 PM
Undy
Undy's Avatar
Location: Virginia Beach, VA & Port Charlotte, FL (snowbird)
Received 1,095 Likes on 578 Posts
A lot of times it's a soft cam that eats the lifter.
Old 12-05-2016, 09:07 PM
Unreal
Unreal's Avatar
Or a loose cam gear.
Old 12-06-2016, 01:31 AM
RamAir972003
RamAir972003's Avatar
My comp cam ate all my lifters comp does not stand by their products I can tell you that.....look at my build due ti soft cam...
Old 12-06-2016, 08:42 AM
RedZ4me
RedZ4me's Avatar
...........too much spring pressure?
Old 12-06-2016, 08:43 AM
RedZ4me
RedZ4me's Avatar
..................too much spring pressure?
RedZ4me
RedZ4me's Avatar
Too much spring pressure is also often a cause
Old 12-06-2016, 08:44 AM
RedZ4me
RedZ4me's Avatar
sorry for the duplicates, wasn't posting until I refreshed the page. apologies
Old 12-06-2016, 09:00 AM
Synacks
Synacks's Avatar
I should know more in a couple days but everything I have is stock and 2009 Z06 with 40,000 miles.
Old 12-06-2016, 09:02 AM
Synacks
Synacks's Avatar
Oil pressure was fine. Car drove fine but it occasionally misfired at idle and would throw a check engine light for cylinder 2 misfire.
Old 12-06-2016, 09:32 AM
Unreal
Unreal's Avatar
Its going to be a chicken/egg thing. Cam could kill lifter, or lifter can kill cam. Also could be cam gear backing out. Seen all 3 take out a lifter.
Old 12-06-2016, 11:01 AM
50 4Ever
Wil Cooksey #256
Support Corvetteforum!
50 4Ever's Avatar
In GM's wisdom, the oil pump is located between the pan and the filter. With all that crud going through the pump it could be damaged also.
Old 12-06-2016, 11:15 AM
Katech_Zach
Premium Supporting Vendor
Katech_Zach's Avatar
C7 of Year Finalist (track prepared) 2019
...or poor valvetrain dynamics beating up the lifter.
__________________
Contact:
(e) zach@katechengines.com
Old 12-06-2016, 11:22 AM
outhouse
outhouse's Avatar
Process is taking valve covers off and inspecting.
Guy last weak thought what you did and it was just a busted spring, they used a bore scop and found the piston was in perfect shape, new spring and the guy was down the road.
If it is a lifter heads come off for lifter/cam exam.
To Faulty lifter ate the camshaft
Old 12-06-2016, 11:24 AM
outhouse
outhouse's Avatar
Excellent advise, but if his oil pressure was fine it may not be in bad shape.
If he gets that low in the motor, I definitely would take a peak see
Old 12-06-2016, 11:57 AM
Michael_D
Michael_D's Avatar
The OEM .700" lifter wheel and 1.8 RR are not what I considee a good match. I'm a broken record at this point...... I do not like GMs .700" roller wheel. Not saying that is what happened here, but it doesn't help.
If the cam lobe is gone, an engine tear down is highly recommended.
Old 12-07-2016, 08:28 PM
Synacks
Synacks's Avatar
Do you or anyone else recommend something better? Obviously I am going to have to replace them and want to replace with something better than the terrible factory ones.
Quick Reply: [Z06] Faulty lifter ate the camshaft
