[Z06] 09 cai question
09 cai question
Hello all new to forum
I have a 09 zo6 completely stock and I purchased a vararam cai for the vehicle that I would like to install. The ? Is do I absolutely need a tune after installation or can this system be installed and driven "as is" with no repercussions down the road ? Thanks in advance
Wow now I'm really confused!
To completely different ends of the spectrum.
Are either one of these determinations based on actual personnel experience?
Sorry and thanks
Sorry and thanks
The Halltech MF103 w/beehive is about the only CAI that doesn't require a tune. You can also run the Callaway Honker, but you need to order their "diffuser plate" for stock tune cars, since the blade style MAF on these cars are susceptible to turbulence.
As for personal experience, I don't like the Vararam products...fit and finish has always been called into question (even dating back to my C5Z days). Do they work? Yeah...they do. There's other CAI's that work as well though, without all the fitment issues. The install on the C6Z hacks up the radiator shroud quite a bit, resulting in the loss of high pressure air being forced through radiator...which can cause your car to run hotter than it did pre-install. I've read this on more than one occasion.
Thanks all! great venue here. Back to the drawing board!
It won't be going on till I've exhausted all my resources 😩
I also have active gmpp on the vehicle that I worry about if something did go wrong they would blame the add on and refuse warranty payment.
BTW any one wanna buy a new Vararam intake?😁
for an otherwise stock vehicle, save your money on an aftermarket cai.
Not comparing at all just bolted it on my 08 and put on around 1,000 miles no issues thats all, o then i had it tuned and fyi the corsa was around 20 hp it likes dynos just saying have a great day, I think it is the best looking carbon intake out there,alot of compliments at shows.
I installed a Corsa 45962 CAI and have no issues running Diablo 93 tune.
Note - you do have to cut a hole in the cover to fit the scoop in.
No I don't have cooling issues, running stock the thermostat and I live in Texas
No I don't have water ingestion issues and I have driven it in the rain.
