[Z06] Max effort NA Cam suggestions
See sig. 599RW on SATX summer heat! Mild cam with 19* overlap.
BTR Stg 4 NA cam
the fastest na cars run this cam. i personally have it and its a monster
After I did my build
https://www.corvetteforum.com/forums...post1592234877
with K501 cam (a little more than yours), MSD, NW102 and Pfadt 1 7/8 LT's I found out the Pfadt LT headers do not generate as mych torque asseveral other headers. I think my build will do what I want, but if I were to replace them now I'd probably go to ARH 1 7/8's and get probably 20 lb-ft more torque in the 4500-5500 range. My power peak was 7100 RPM (7300 FSO) with the Pfadts, about 4-500 rpm higher than similar builds with ARH. After my build, even Katech indicated the Pfadts typically generate less mid-range torque than other headers. My MSD was just mildly cleaned up, not really ported.
The Pfadts seem to work best on stock or mild cammed LS7's.
Other than that, tuning is a big issue with cars that are "down on horsepower".
That said, I do not think he is all that low on overall horsepower. 560rwhp on a stock intake manifold and TB...well, a ported MSD and 102 is good for another 35-45rwhp which would put him right on track with all the other setups out there, including ARH & kooks powered vehicles. I don't know about you but if I were able to get my cam/header selection to make 590rwhp, I'd be pleased considering how streetable my cam is. Anything over 580/530 in my book is a great success with pump gas, streetable cams.
I'd be interested in seeing the dyno graph and take a look at the power under the curve.
fueled, not sure if you were looking for my dyno runs but see post #98 here for mine:
https://www.corvetteforum.com/forums...-intake-5.html
Any of our "Widow" series cams will do the job.
Ask me or many others how we know...
www.vette-air.com
Thanks,
Carlos
www.vette-air.com
Thanks,
Carlos
For max effort, your best bet is to work with a vendor and get a custom cam that works well with your setup. Having well paired parts/cam specs will give you better results. There have been a lot of promising results lately with Tony's head/cam/manifold packages, so that could be a good place to start.
For off the shelf:
BTR stage IV is a proven setup and is supposed to be easy on the valvetrain.
The RPM B-3 cam has also put down some impressive times/mph, Fran posted video/slips of a 9.8 at 142 in a full weight car with their head/cam package.
For off the shelf:
All that said, when I dyno'd my H/C with no other mods, I made 500/450 heat-soaked @ 88* outside and the power was unchanged until about 3-3.5K, just like yours did.
However, my 1 3/4 Pfadt's picked up boat loads of torque from 2-6K, especially from 2-4K and that is just the seat of the pants feel. I imagine after a retune, if I did nothing else, I'd see close to 500rwtq on that setup alone. Put the ported MSD and CAI on and I imagine 520-540rwtq is attainable. Anyways, not to get off subject but something else I need to point out that I have learned about my cam that makes it unique.
1) Is that the .006 lift is 288/298, which is fairly aggressive - at least seemingly more aggressive than the 236/244 at .050" lift So you need to look at a both lift locations on the cam, not just one or the other. I never understood why people put so much stock in this measurement alone, considering that a camshaft is not a perfect circle and that the lift @ .050" is exactly one spec and one spec only on a camshaft that constantly changes. In my cam's case, it is asymmetrical and a single point of measurement cannot tell you anything significant about how that cam will perform on the street OR the dyno.
2) The advance in the intake side makes a difference where that power is made but certainly affects tune-ability.
3) The most important perhaps, is that my cam is ground in such a way that the ramp rate is aggressive - (the little curve that indicates how quickly the cam reaches peak lift) - mine resembles that of a solid roller cam. Not quite that aggressive but pretty close. And as such, the car behaves in a violent manner @ WOT. It also gives the car an unusual lope. Choppy at times but usually it "gallops" in concert. My engine builder spec'd the cam to open violently but close more gently, with a change in the rate it closes right before the valve touches the seat again. This was intentional to avoid hammering my valves - a longevity concern I guess you could say. This same cam has made 590/560 on Pfadt 1 3/4" headers with stock intake manifold and TB. Sounds impossible, I know. But there are others that made similar power with the same cam. So I know that if you have a competent tuner, you can really work some major gains out of the LS7 with a very modest cam selection. No need in having 260/280 splits to get power. The goal is to get the engine building torque and using it's multiplying factor to build more torque, sooner. You end up with a fatter power band and one that holds it's own up to a certain RPM. It is so common to see people over-camming their cars and never really taking advantage of the full potential of the lift these cams have.
A really well made cam can easily cost $600-800 cam only price if done right because there are so many things that should be looked at other than the .050 lift specs and LSA. Those matter but they don't address everything.
The only change in my build from most others with the K501, MSD, NW102 was the Pfadt 1 7/8" Tr-Y headers. Several forum members and Katech indicated low torque numbers from this particular header on medium cam builds like mine. The other "anomaly" was that most builds with that cam peak at 6600-6700 RPM and mine peaked at 7100 RPM. I saw one of the earlier tuner dyno runs that was similar down in the torque area, a little higher but then the tuner backed down the A/F ratio for an extra margine. I don't know if having the dyno runs and tune done on 91 octane unleaded had an impact. The "after" dyno runs were done in 93-94* heat, but SAE corrected, ~ 5% increase over uncorrected, which is why the stock injectors were able to keep up. The majority of my performance events will be done at 1200-6000" altitude.
The same dyno was used before and after. The before results virtually traced stock dyno runs done on another dyno.
This weekend I should get a read on the performance gains over stock as I'll be doing the No-Fly Zone AZ 1/2 mile roll races. Stock with an honest 40 MPH rolling start it typically trapped at 154 MPH.
Anyone have any experience with the cammotion low lash solid rollers? Or solid rollers in general? I know i'll have to run a different style rocker at the least.
Also, thoughts on the callaway honker intake? Are there better ones out there or should I be good? I feel like an air intake is an air intake.....but ive been wrong before.
Callaway Honker is a fantastic intake...ran it on my C5Z which made great power. Only reason I didn't put one on my C6Z is I have the factory tune. You'll get MAF turbulence/surging on a stock tune. I went with the Halltech MF103, because it's compatible with the stock tune...and I don't feel it's really a compromise, since Katech uses Halltech intakes. Money no object...LG's Super Ram is a work of art. Essentially a Callaway Honker mated to a Varam...IMO. There was a guy recently trying to sell a Honker in the parts forum...I damn near wanted to buy it myself because he didn't have any offers. Not sure if it sold though.
REDZED2 (12-15-2016)
#33
PM coming
#34
Yeah, the LG is artwork...expensive, high-end artwork. Its all Carbon Fiber; which LG said was necessary for it to keep its shape under speed...if it were plastic, it may cause the inlet area to collapse on itself or distort. Josh B picked one up for his current build...looking forward to his reviews.
#35
take it as you will but here is a built 441 lsx w/ fully worked over Brodix BR7 heads and no idea on the cam making 695 to the tires (camera car) vs me in my FRH Stock ported/ milled heads and BTR Stg 4 cam with full exhaust (Silver, stock intake, injectors, tb, sbe).
@ 0:35
@ 0:35
#36
Picked up 17rwhp on 50 water 50 meth spray....300 dollar kit...i installed free...id lkke to see what i get from 93 and 100percent meth with my compression bumped. ....
#37
MTPZ06 (12-19-2016)
#39
@ 0:35
https://youtu.be/9w6Sjr1FhJQ?list=PL...Q16qXq55Y7TXTV
@ 0:35
Looks like that dude had a very happy dyno.
Millenium Z06 (12-20-2016)
#40
LOL 695 my *** more like 560 that's what people would tell me around here in making 620 plus on pump gas blah blah blah till we run then I pull on them not naming what vendors they used, lets just say it was disappointing and I'm in Dallas with lots of good shops....happy dyno for the win....
