C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Help me choose 19" drag radials dedicated for 1/2 mile and 1/4 mile events
Old 12-21-2016, 07:43 PM
lamboworld
lamboworld's Avatar
Default Help me choose 19" drag radials dedicated for 1/2 mile and 1/4 mile events
I am going to use my 19/18 OEM Spyders as a dedicated track setup. I will use these wheels/tires mostly in 1/2 mile events but I will also use them in a few 1/4 mile events as well.
Which tires should I consider?
Old 12-21-2016, 08:16 PM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Only 19" DRs made that fit OEM z06 wheels are nt05R, so pretty easy choice.
R888s are suppose to be out soon, but they are not drag radials. No other DR fits, so NT05R or pick a non-drag radial.
Old 12-21-2016, 08:33 PM
Z06Qazi
Z06Qazi's Avatar
they make 19" mickey thompson et streets...
Old 12-21-2016, 08:56 PM
Unreal
Unreal's Avatar
Not that fits the stock 19x12 rim properly. They are 305s, for a thiner wheel.
My bad, they do now make a 19" 325 ET street SS which is new. So you have a 345 NT05R or 325 ET street SS. I'm not a fan of the Street SS.
Old 12-23-2016, 08:55 AM
Schred86
Schred86's Avatar
i have the nt05r's on my z and nitto invos up front. its a nice combo. run 18-20 lbs in rears and they hook
Old 12-23-2016, 09:38 AM
KM177122
KM177122's Avatar
I'm running NT05Rs as well. They hook well when fresh. As discussed in another thread DRs don't seem to hook very well much past a couple thousand miles.
Old 12-23-2016, 10:14 AM
AzDave47
Support Corvetteforum!
AzDave47's Avatar
Received 4,509 Likes on 2,598 Posts
I have the MT ET SS 325/30-19s and ran them at the NFZ 1/2 mile roll races this past weekend. Temps were 50-60*. My car is 602/489 rwhp/tq with Bilstein shocks. I did no standing starts so did not hit it hard. My runs were ~40 MPH roll at the start. The car hooked up solid with either a 1st or 2nd gear start and hooked on the 1-2 and 2-3 shifts. Traps were mostly 163-4 with the first one 166.8, tach at about 7K at the traps. Tire pressure was ~ 30 PSI, Traction Control off. The car was moving around some in 4th gear but I don't know if that was the tires or the runway paving or light side winds.
I drove them about 150 miles each way to the event. Driving down the day before was in light rain on 65-70 MPH roads and they were OK. That was their first use.
FNBADAZ06 (12-23-2016)
Old 12-23-2016, 11:10 AM
MickVette
MickVette's Avatar
St. Jude Donor '13
I'm giving the MT ET SS 305/35-19 on the stock Spyder rims a try. The rims are on the very wide end of what is "approved" on the M/T web page for a 305.
http://www.mickeythompsontires.com/strip/et-street-ss/
Once mounted I see they offer no rim protection at all but I will be using these for 1/2 mile and 1/4 mile only. I do have a concern about the 1.5" difference in height from the front to rear and having ABS controller issues. My race is Jan 22nd, so I can update the results at that time.
Thanks for that information. I was going to drive my about the same distance and was wondering the street manners.
Old 12-23-2016, 05:39 PM
STANG KILLA SS
STANG KILLA SS's Avatar
i didnt think DRs were legal for half and 1 mile events.
i was reading the rules for texas mile and they mentioned that. even had to have tires rated to the speeds you were running
Old 12-23-2016, 06:06 PM
AzDave47
AzDave47's Avatar
I will be running the Mojave Magnum this April (1/2, 1 and 1 1/2 mile, goal 200+ MPH). The 2017 tire rules are not out yet but here are the 2016 rules, which include MT ET S/S that I have:
http://www.mojavemile.com/images/pdf..._List_2016.pdf
Omega Motorsport put on the 1/2 mile No-Fly Zone event I did this past Saturday and drag radials were allowed.
Old 12-23-2016, 06:14 PM
Unreal
Unreal's Avatar
Depends on event.
Old 12-23-2016, 09:46 PM
Tech
Tech's Avatar
I have the Street S/S. No complaints for what you're using them for.
Old 12-23-2016, 10:02 PM
KM177122
KM177122's Avatar
Depends on the event. I know you can't run them in the Texas mile. Some 1/2 mile events will allow them do to mostly slower trap speeds.
Old 12-27-2016, 11:50 AM
0Anthony @ LGMotorsports
Former Vendor
Anthony @ LGMotorsports's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
How much power does the car make? If it is pushing 900+rwhp (or less really) I wouldn't even waste the time on a 19" setup.
Old 12-27-2016, 01:55 PM
ExoticMotorClub
ExoticMotorClub's Avatar
sub'd
Old 01-01-2017, 08:34 PM
lamboworld
lamboworld's Avatar
I am at around 580 whp and 700 whp on Nitrous. I don't plan on going past 725 or 750.
I am leaning toward the Nitto NT05R and I am wondering if it would be best to go with the 305/19 or 345/19 for the rears.
Old 01-02-2017, 12:05 AM
MickVette
MickVette's Avatar
St. Jude Donor '13
345's. I put the 305's on my spyders and they just don't look right. The rim is at the maximum recommended width for the 305's. Wish they had a 345 available in the MT ET Street SS.
To Help me choose 19" drag radials dedicated for 1/2 mile and 1/4 mile events
Old 01-02-2017, 09:54 AM
Schred86
Schred86's Avatar
I have the 345/19 nt05r. definitely go with that size
Old 03-03-2017, 02:53 AM
lamboworld
lamboworld's Avatar
I am bumping this thread back to the top wondering if it is even necessary to run drag radials in a 1/2 mile event. I am debating if it is even worth it if I can achieve the same speed with street tires vs drag radials. Any real world results.
Old 03-03-2017, 07:41 AM
FNBADAZ06
FNBADAZ06's Avatar
Can you spin the street tires from a 2nd gear roll ? If the answer is yes, drag radials will be a very useful in achieving max velocity...even in a 1/2 mile race.
Quick Reply: [Z06] Help me choose 19" drag radials dedicated for 1/2 mile and 1/4 mile events
