C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Upcoming build... couple questions
Old 01-25-2017, 09:14 PM
SPDKLZ1
SPDKLZ1's Avatar
Default Upcoming build... couple questions
I'm planning on going to DRM in a few months and having them ship my heads to AHP for their #4 head package plus porting and stock tb porting, Callaway CAI, ported MSD, and BTR Stage 2 cam on a Cam Motion grind. I was set on AR headers but just found out about Hooker Blackheart LTs that I can get for $500 less with the x-pipe and cats than AR. Thoughts on the Hooker headers vs AR and any other parts of the build are encouraged...
Thanks, Jesse
Old 01-25-2017, 09:40 PM
meinersk
meinersk's Avatar
Pulling out my big cam for a bigger cam....go big early ......like when you are at a bar at night.....just got 2in kooks for 850 shipped maryland speed...gl
MarylandSpeed (02-03-2017)
Old 01-25-2017, 09:44 PM
outhouse
outhouse's Avatar
Great choice.
They set the standard here, and its worth the extra money.
Old 01-25-2017, 09:46 PM
MTPZ06
Support Corvetteforum!
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
Thanks, Jesse
ARH headers are the gold standard...I wouldn't replace those with the Hookers. Said it in this thread...they look hideous IMO. https://www.corvetteforum.com/forums...ghlight=hooker
The other thing to note is that they are a Tri-Y design. Pfadt has Tri-Y headers, and they seem to be a bit underwhelming in the results department.
Old 01-25-2017, 09:47 PM
SPDKLZ1
SPDKLZ1's Avatar
I hear ya, but I was thinking Katech 116 at first and now pretty set on BTR 2-ish specs. I still want to maintain most of the driveability. Are those Kooks without the x pipe?
Old 01-25-2017, 10:06 PM
SPDKLZ1
SPDKLZ1's Avatar
Thanks Outhouse. That's what I was almost certain of after being on this forum for the last couple years. I just wanted to make sure. What about BTR recommending one-piece hardened pushrods for the BTR2 over stock?
Old 01-25-2017, 10:09 PM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
ARH all the way. LG would be 2nd choice.
Couldn't pay me to run hooker
Old 01-25-2017, 10:14 PM
SPDKLZ1
SPDKLZ1's Avatar
Who has the cheapest AR headers and catted x-pipe? I'm slowly starting to put my orders together. This is going to be 99% street at the moment but wouldn't mind embarrassing some C7Zs this summer. I hope the MPSSs can hold!
Old 01-25-2017, 10:19 PM
Unreal
Unreal's Avatar
Hmm
Joe@CPR
Fran@RPM
Not sure who else. I always bought direct from Sexy Steve@ARH.
Old 01-25-2017, 10:28 PM
SPDKLZ1
SPDKLZ1's Avatar
I'll check them out tomorrow. Thanks Unreal
Old 01-26-2017, 12:30 AM
meinersk
meinersk's Avatar
Get used headers. ...im taken off my lg 1 3/4 super pro longtubes and selling like 450 bucks....lots of guys selling 1 7/8.....no not with x pipe for kooks,,
Old 01-26-2017, 06:15 PM
SPDKLZ1
SPDKLZ1's Avatar
Is there any reason to not get 2" headers if I can get them for $50 more than the 1 7/8 headers? NA with a future HP around 550.
Thanks, Jesse
Old 01-26-2017, 06:39 PM
MTPZ06
MTPZ06's Avatar
Thanks, Jesse
No, none.
Old 01-26-2017, 08:21 PM
SPDKLZ1
SPDKLZ1's Avatar
Thanks MTP. 2" it shall be.
Old 01-27-2017, 11:27 AM
outhouse
outhouse's Avatar
I run BTR and AHP recommended then.
Stock would not fit and you will have added spring pressure, don't skimp here.
Old 01-27-2017, 11:48 AM
SPDKLZ1
SPDKLZ1's Avatar
What length? The 7.775" LS chromoly 5/16 diameter pushrods? Stock is 7.8" I believe.
Jesse
Old 01-27-2017, 11:58 AM
SPDKLZ1
SPDKLZ1's Avatar
I just talked with a guy at BTR and he said to most likely go with the 7.800 pushrods because I'm not milling the heads, just a cleanup pass. Running 91 octane
To Upcoming build... couple questions
realcanuk
realcanuk's Avatar
St. Jude Donor '13
Jesse
You have to measure to get proper pushrod length.
Old 01-27-2017, 12:02 PM
SPDKLZ1
SPDKLZ1's Avatar
Thanks realcanuk. I'll just wait on those and have the shop take care of that.
Old 01-27-2017, 12:25 PM
American Heritage
Supporting Vendor
American Heritage's Avatar
Received 1,012 Likes on 533 Posts
Jesse
The LS7 uses 3/8 diameter pushrods. The stock LS7 pushrods are 7.800".
We typically like to run 7.775" hardened 3/8 diameter pushrods in our in house builds. You can run the stockers but we like to lower the preload a little and put it more in the middle of the lifter travel.
We sell pushrods and can gey you the correct size with your head order. We offer free exchang (minus return shipping) if you end up wanting or needing to go with a different size.
Hp@americanheritageperformance.com
Quick Reply: [Z06] Upcoming build... couple questions
