[Z06] Greddy Exhaust - 27.2whp / 34.7ft-lb gains. Anyone have this?
I see that Greddy is now making an exhaust for the Z06. I used to have these on some of my Import cars and they were great.
They claim a 27.2whp / 34.7ft-lb increase! Seems like a lot.
Anyone do a back-to-back stock vs comparison with the other popular exhaust like a B&B or Akrapovic? I wonder how much increase they show?
Here is the link I saw it at: https://www.shopgreddy.com/collectio...ducts/10188300
No way in hell an exhaust does that. Complete horseshit.
I'll admit that at least it comes with an "X" mid-pipe, and looks like a well constructed system. Not a fan of the two tip system though.
Its even a stretch to believe Akrapovic's claim of 13hp for their evo system; but damn, at least they aren't in the realm of outlandish.
Sounds good, jury is out for me on the looks. I agree with the above posts on hp gains, unless it's a full system with LT headers, really hard to believe that's the case for the advertised price for 1k.
Even with a tune.
On a 1000+hp car, going from stock to full 3" is ~5-10hp. Stock systems have made 1400+rwhp. There is no way a factory system to anything is adding over 20rwhp. Not going to happen. Just more made up marketing crap.
Yep, new exhaust--- +25 hp
new CAI--- +25 hp
new hood seal--- +20 hp
lose the door jamb emblems --- less 1/2 lb=5 hp
nitrogen in the tires is an easy 30 hp + loss of 5 lbs
painted "Corvette" letters is probably good for 5 hp
new CAI--- +25 hp
You forgot that 20HP for intake manifold insulation
LMB-Z (02-21-2017)
outhouse (03-19-2017)
Looks odd from the rear. Would look much better with a diffuser designed for dual tips.
But stock is 3" (even with the neck down at mufflers in the back). You would buy this system for looks/sound/weight. Not power. No aftermarket system has shown more than 5-8rwhp, and even that is typically "let it cool off on dyno" gains.
Received 2,061 Likes
I see what happened there. They got their numbers mixed up between the weight, power and size.
The weight difference is 24.5 lbs and they added a 2.7 whp gain to get the 27.2 whp.
Then measured the total length of the pipes and mufflers (12.9 feet) and added the weight (24.5 lbs) to get the 34.7 ft - lb.
It all makes sense now. Just pick an assortment of measurements and add and re-label them as desired.
Maybe they mean peak power difference which would make sense (not peak numbers but peak difference). Closed valves on stock system typically is ~30rwhp. So if you did a check at 3000rpm before valves open, a 30rwhp/30rwtq at 3k is completely believeable assuming they are checking there.
Or they wired the valves shut and compared to that.
Pro Mechanic
It's the New Math!
