C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Please help me diagnose this rear vibration after motor build.
Old 03-04-2017, 07:33 AM
JonSnow
JonSnow's Avatar
Default Please help me diagnose this rear vibration after motor build.
Question for you guys
I just had a new motor built for my Z (New heads, rods, pistons, erl shortblock, the whole shebang) about 75 horsepower over my last setup.... After getting everything dialed in and broken in I went for some test runs ( getting on the throttle ) and while doing a full 3rd gear pull this loud horrible vibration starts coming from the shifter, to the point where the shifter is difficult to hold onto (like one of those carnival games with the vibrating stick) it only happens when applying power, any sort of power input to move forward it makes noise and it feels like the brakes are being applied!
Edit
Ended up pulling the torque tube apart and everything in there is fine (bushings intact etc) While there I also looked at the clutch (McLeod) and again. Looks fine and is adjusted properly.
If you let the car sit for a while then drive its fine, however once you start applying real power it does it again.
Any other thoughts as to what it might be? How do I isolate whether it's the t56 or rear end? Is this a common symptom of rear end or t56 failing
Old 03-04-2017, 07:57 AM
double06
double06's Avatar
Maybe motor or trans mounts starting to go.
Old 03-04-2017, 02:52 PM
JonSnow
JonSnow's Avatar
will try that next thanks
Old 03-04-2017, 08:01 PM
Dirty Howie
Dirty Howie's Avatar
Edit
Did you make sure your shifter is not loosened up?
Does your motor vibrate just revving out of gear?
DH
Old 03-05-2017, 02:46 AM
harrydirty
harrydirty's Avatar
Sounds like clutch is slipping............
Old 03-05-2017, 05:31 AM
JonSnow
JonSnow's Avatar
I have a new McLeod clutch in there I put about 1500 miles on it, after inspection it still looks good.
I sure hope the clutch can handle 580 hp!
Thanks for the response
Old 03-05-2017, 11:29 AM
meanjoe
Support Corvetteforum!
meanjoe's Avatar
Old 03-05-2017, 07:02 PM
redcycle13
redcycle13's Avatar
I know you said you pulled torque tube and everything looked good, but I had a similar feeling after a new engine build. After I had the torque tube out the second time I found the pilot bearing was trashed. Just a thought.
Old 03-05-2017, 07:47 PM
stefuel
stefuel's Avatar
I know you re balanced the engine after going with different pistons..........right?
Old 03-24-2017, 04:23 PM
JonSnow
JonSnow's Avatar
thanks will take a look at that as well
Old 04-19-2017, 08:52 AM
JonSnow
JonSnow's Avatar
thanks for everyone's help.
pulled the tranny and the fluid is full of metal.
Old 04-19-2017, 09:41 AM
Dirty Howie
Bummer ....... did they add correct amount of tranny fluid after new motor was installed??
DH
Old 04-22-2017, 06:11 AM
JonSnow
JonSnow's Avatar
DH
it's one of those things that even if I ask I don't think they'd tell me
this is what I get for buying someone else's modified car. ;(
Old 04-22-2017, 08:28 PM
Dirty Howie
Well,could be worse like a new motor. Let us know when its up and running good again
DH
Old 05-29-2017, 04:38 AM
JonSnow
JonSnow's Avatar
installed a TR6060
the car now grinds from the 4 to 6 shift.
ive replaced the entire motor in this car, torque tube, clutch and now transmission, I'm ready to throw myself off a bridge.
To Please help me diagnose this rear vibration after motor build.
Quick Reply: [Z06] Please help me diagnose this rear vibration after motor build.
