[Z06] Feedback on Kooks 2" vs ARH 2"
Looking for some feedback on Kooks 2" vs AHR 2" headers.
The Kooks have a "D" shaped flange vs the "Round" AHR flange.
Any pics of the Kooks collector? Dyno results?
This is specific to the 2" version.
Thank you all!
Thank you all!
I could be wrong, but I thought the whole "D" vs "Round" port thing has been proven that neither has any benefit over the other. Now as to header design, fitment, power, etc...I'm interested to hear real conclusive data...however that may be captured. I'm guessing they're extremely similar from a sheer numbers standpoint.
That's what Im looking for. Collector design, primary length, and any dyno or dyno comparison as well as any feedback with fitment and such.
I ran Kooks on a different platform and they do make great power.
Im also considering SW Headers in their 2" version. There is a local Z making a bit over 640RW with stock shortblock, Holley High-Ram that runs this header. She is a beast.
http://stainlessworks.net/chevy-corv...006-13-headers
On a 2" header the flange port is bigger than the head anyway so it doesn't matter. ARH headers are on more record breaking LS cars than any other header, gm also uses them on its copo program. Iirc ARH used to use d ports on their 2" flanges but later found they served no value
On a personal note I have installed Kooks and ARH 2" headers....this is not going to be a popular opinion but the kooks quite honestly sucked compared to ARH in terms of install and fitment
I have installed all three major brands of corvette headers.
Fitment from best to worst:
ARH
KOOKS
LG
Construction quality best to worst
ARH
LG
KOOKS
ARH is hands down the superior header, we are lucky to have them for the vette. The 2" ARHs I just installed on my personal car tuck beautifully around the engine bay and ZR1 oil cooler. Amazing really.
ARH
KOOKS
LG
ARH
LG
KOOKS
The following 2 users liked this post by Josh B.:
ElisTwoCents (12-05-2020),
HC Mechanic (06-14-2019)
I believe the ARH uses a merge collector, while the Kooks uses a straight collector. I know the ARH has a merge spike, not sure on the Kooks.
I believe the merge collector is good for a measurable bump in torque over the straight collector due to the increase scavenging.
Location: Virginia Beach, VA & Port Charlotte, FL (snowbird)
Received 1,092 Likes
You should do a bit of research before you declare a claim to be false, really. I am correct.
Kooks 2"....straight collector
https://www.kooksheaders.com/automot...3-headers.html
ARH 2"....merge collector
https://www.shoparh.com/collections/...13-long-system
Some photos of C7 ARH vs Kooks headers:
Source:
https://www.corvetteforum.com/forums...ts-inside.html
Source:
Da Z06 (03-12-2017),
Source:
Source:
I put my 1 7/8" Kooks on my car over 10 years ago and they do have merge collectors.
http://marylandspeed.com/kooks-1-78-...400-p-499.html
http://sho-mespeed.com/component/hik...ry_pathway-751
http://ls1tech.com/forums/advanced-e...ollectors.html
The thread is about 2" headers. You tried calling me out for being incorrect, I let you know that you stand corrected, and you tell me I should "specify" 2" in a 2" thread? You were mistaken in the context of this thread, you throw out "not true" accusations, but you are above admitting when you're wrong? I'll keep that in mind when I read your comments from now on. It's about sharing knowledge.
ir0nman11 (01-31-2020)
I'm not in error. Kooks offers 2 different collectors for their 2" primary LS7 Z06 header, straight and merged. I won't belabor this any more and post links. This is your thread and I'm out. Let me know though and I can PM you the links should you decide.
I've installed 4 sets of kooks on various cars and 3 sets of ARH....kooks quality has never impressed me for the money and the fitment on all cars was less than optimal. ARH on the other hand has always went right in with plenty of clearance
Had kooks 2" on my Z06 and was not impressed for the money. Installing them was a b!tch on the pass side. Once in they werent bad. I didnt like the X-pipe either. I had to use a ratchet strap to install them. I will be trying the SW 2" headers on my new car though, I have seen the quality of those headers and it is way up there and $400 cheaper. Now as the "D" vs "O" port, as long as there is no interference in the flow, there will be no gain or loss. Now if there is an interference there will be a loss due to a reverence in exhaust gasses causing knock. My particular heads, the "D" port caused an interference and this is what I saw. So I installed the 2" Kooks w/ no cats and saw an increase of 45 RWHP over the stock manifolds. This is just my personal experience.
