[Z06] Fast 102 lsxr sensor?
Not that I have seen...Just use a larger bolt head, or a washer to retain the sensor in place.
Even with lots of boost, this setup has worked for many...
Contact FAST/Comp Cams and they will sell you the correct mounting hardware. Don't forget to drill the hole for the MAP sensor before you mount it
