[Z06] can you improve the flow of stock ls7 heads
I'm having my heads done, the shop said he could cnc them further, aren't they already done at the factory? He claims an additional 30hp.
Here is the before/after dyno sheet of my Z06 when I had the WCCH heads installed.
Before dyno was when my car had cam, intake, headers, Fast intake. Only change for the after dyno pull was the WCCH heads. Gains are definitely believable if you have the right cylinder heads.
Then go have fun..
There is a set of OEM heads that have been recently ported and rebuilt by Tony Mamo on the C6 for sale board. New PAC 1205x springs and solid stemmed exh valves. The guy decided to not use them. He also has a Mamy ported MSD, shaved and painted. I'd buy the heads just to have on hand, but I already have two sets.....
Someone should jump on those pretty quick.
I've seen 50+rwhp gains just swapping one brand of ported heads to another.
I've seen heads lose 20-30rwhp. I've seen heads gain 30-40rwhp. All stock casting LS7 heads. So yes, there is a lot of power to gain or lose.
On average, how much HP TQ gains could one expect to see on a set of stock LS7 heads if they are race ported and milled .010" from a very reputable shop that has tons of experience with LS7's?
Its an overall thing, not just heads.
Anywhere from 20-50rwhp I would say. Depends on cam, intake, etc. If it is a small cam, stock intake, etc. compared to a large cam, high compression, ported MSD.
Now that same car with intake, headers, exhaust and tune has the heads race ported and milled .010" how much increase over stock heads?
5-35rwhp depending on a ton of things, dyno, etc.
Why only a 10 mill?
Why only a 10 mill?
So?
Cali, Utah, etc etc all run 91 and I wouldn't go below a 30 mill (depending on cam of course). Seen 20rwhp on 91 octane just from a 30 mill.
He said they usually only mill to .010 in shop to avoid any knock issues from using 91 octane gas since milling raises compression and milling too much with 91 will cause knock.
