C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Interesting results with Dyno 2000 software...
Old 01-17-2005, 08:30 AM
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Support Corvetteforum!
Scissors's Avatar
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
Default Interesting results with Dyno 2000 software...
So I decided to plug in the LS7 numbers that we already know and just guessed at the things we don't to see what Dyno 2000 says.
Interestingly, it came up with almost exactly the reported HP and Torque numbers.
Things we know:
4.125" bore
4" stroke
2.2" intake valve
1.6" exhaust valve
11:1 compression
655 CFM induction
SFI
Int/Exh lift is 0.591" @ 0.050
Roller hydraulic lifters
Things I had to guess:
Generic large-tube header, open exhaust
Generic Dual-purpose street/track cam
Generic Wedge/Fully Ported large valves
-109 lobe center
-64 valve overlap
-282 intake and exhaust durations
-IVO (BTDC) 32 degrees
-IVC (ABDC) 70 degrees
-EVO (BBDC) 70 degrees
-EVC (ATDC) 32 degrees
-ICA (ATDC) 109 degrees
-ECA (BTDC) 109 degrees
-Nominal timing
Now if someone could fill in my guesses with facts, that would be nice.
But, yeah, with those guesses the virtual dyno came out very close to reported numbers.
Old 01-17-2005, 09:22 AM
WhiteDiamond
WhiteDiamond's Avatar
St. Jude Donor '15
It will probably be a long while before we have cam specs for this motor
Todd
Quick Reply: [Z06] Interesting results with Dyno 2000 software...
