C7 Edelbrock E-Force Supercharger info :)
#61
Just an FYI, Cornerstone is used by pretty much ALL of the supercharger manufacturers that offer supplemental warranties, not just Edelbrock... I would suggest trying to get in touch with Cornerstone again.
#63
Just tried again yesterday spent about 3 hours with no luck! There automated phone system went to 6 different departments waited 30 minutes each no one answered.
That is a shame if all supercharger manufactures use them and don't keep better tabs on them!!!
#64
Roush uses them (or at least used to use them), never seen anyone that actually made a claim with a failure though. The canned tunes that they warranty are usually pretty weak but anything can fail.
Used to be capped at 8000.00 as well, I guess its cheap insurance if you are going to stick with the original tune but a waste if you are going to custom tune.
#65
Maybe someone will pick that up.
#66
Tried it all!
Thanks just wanted to make sure everyone was informed so they could make an informed decision. Which I would have talked to someone first before sending my money in and getting ripped off. I guess I thought if Edelbrock was promoting it was good company.
#67
Contact Edelbrock ASAP. IF all else fails, you can file a complaint with the BBB and your State Attorney's General Office.
#70
Then a complaint with the State Attorney's General Office should get their attention. If the facts that you are claiming are all true/accurate, this is a "misrepresentation" from BOTH companies. If you installed the Edelbrock unit with the promise that by doing so with their stock canned tune, that you could pay an additional fee to purchase a powertrain warranty; then both companies have failed you as a consumer. Edelbrock by misrepresenting themselves with a false claim, and the warranty company by not honoring the said warranty.
#72
Hello Guys I wanna ask about the CNC Heads from WeaponX?
My C7 Zo6 has, 2.31 upper pulley+ 9% harmonic balancer+ air intake filter+ LMR heat Exchanger+ 160 Thermostat+ D3P shroud fans, My question is if I installed the CNC Heads do I need to install the camshaft with it or the stock camshaft is enough? One more thing If I need to install the Racing camshaft I do not want the aggressive camshaft I hate the loud sound.
help please.
help please.
#75
