My photo illustration of A&A install plus Vengeance Racing dyno tune
#62
Hey, I just got my tune done, and had a question for you... what number did Vengance tune your meth to?
Mine is set on about 4 and never actually turns green when spraying. My tune shows a decent wot A/F ratio, but I wanted to see what you were tuned at.
#63
If your LED is not turning green you have a wiring issue or set up issue and need to correct it.
First make sure the light goes from red to green when you push the "test" botton on your remote control box with the gain ****. If it does, your wiring is good. If not, you need to find a better ground source and positive source.
If it does not turn green, you need to adjust the "turnon" on the main controller. Also at the bottom of the pump itself, you can turn an adjustment screw to adjust the point which the lift goes from red to green.
Red means you have continuity....
Green means the unit is seeing at least 50 psi.
I will not rewrite the instructions here, so I suggest you get a copy of the Alky Control manual.
Feel free to call me and I'll explain in detail all the possible problems here. After you get it fixed, you will need to retune the car. I will stumble and hesitate if the meth was not flowing and suddenly you get it flowing without the proper tune.
I can be reached at 918-281-9125
#64
Hey Anthony, all is well here. The car has been running great. I have busy with work and life so not on the forum as much lately but I still respond to threads when I get emails to my thread subscriptions.
How are you and your beast? Did you ever get 1/4 mile testing done?
#65
My gain is set to 5. This is how steep the ramp up in pressure is set.
I read in a few places that a dual-nozzle setup won't ever turn green - now I'm a single nozzle, but I read that it's possible that a high-altitude installation would kinda simulate this. I was just wondering about your experience. I didn't think there was much of an issue, but now I will check for any leaks, and perhaps call Julio.
Oh, when I did the install, I checked the two adjusters on the back of the alky pac, and they appeared to be set for the 2-bar sensor (according to the manual), so I didn't fiddle with them. If there are no leaks and everything is working fine, I may just end up adjusting the screw on the pump itself in order to adjust when the light goes from red to green (as described in step 8 in the manual).
Thanks for sharing your experience.
#66
You need to adjust your screw on the bottom of the pump.
The light tuning red does not mean the pump is building pressure, albeit that I'm betting it is, it only means that it is getting enough voltage to light it up. You have no way of knowing how much voltage or how fast the pump is spinning if at all.
Green is the indicator of how much pressure you are building.
The only way to know is to adjust the screw on the bottom of the pump with a pressure gauge on the line.
At the very least, you need to adjust that screw. It could be set higher than it needs to be for your pressure output.
I did extensive testing with my entire setup before ever starting the car for the first time. I used compressed air (3 psi) on the MAP to simulate boost and dialed the system to turn on at that psi.
Lastly, you want to leave the gain set to what it was tuned at.
However, since it appears you have a wideband and can monitor your A/F, Just keep an eye on what it is doing if you do adjust the gain.
joemosfet (08-01-2016)
#67
I'm Batman..
Pro Mechanic
#68
Received 1,762 Likes
#69
have you needed the "yearly" pump rebuild for methanol? I am seriously trying to hold myself from going to the next step (meth, smaller pulley, LTs) on my P1SC.
#75
I had a glitch with mine leaking bad all the sudden last summer. Turns out the 100*F heat had somehow caused the housing on the pump to loosen up and leak. I took the unit out and dis assembled it. Reassembled it tight and presto - leak gone.
In the process, I find this pump is very simplistic and when the time comes to rebuild, I'll do it myself. Anyone who can change a spark plug can rebuild this pump.
#76
Mine started leaking after a year of use. What Vengeance helped with is buying a second pump to leave on the shelf so we can swap down the road if one needs rebuilt. They are rather inexpensive so it's worth picking up a spare to have on hand.
#79
Happy? Oh yeah!
The performance gains were well worth the cost and effort to install. I had a blast in her! No cats and headers made it offensively loud but it only added to the beast image.
I loved this car but she is long gone. I move on to other go faster cars.
#80
C7 of Year Finalist (performance mods) 2019
My install was about 5k with tune buying used a&a kit and meth about 4 years ago. I did I’d the install myself with 3.8 pulley and later installed 3.46 pulley. On 3.8 I made 600whp and about 579tq if I remember right with 3.46 pulley I’m 640whp and 600 ish to I would have to look back and get specifics . System has been flawless. On second meth pump since install . Like others have said on the message pump fails it dumps all over the floor.
