Procharger: P1 vs. D1?
For a ~600whp (93 octane) car with stock cam, any benefit to the D1 or should I keep it simple with Procharger's base P1 kit?
Do the D1. It gives you more room to grow, if you so choose.
Or go ECS. You get the Novi1500 which is maybe bigger than the D1 and it's in ECS's base kit for the C7.
Supporting Vendor
if you are set on a procharger d1 for sure. If you would like to discuss the pro's and con's of the systems out there let me know. We have installed them all and pushed them all too very hard.
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
480-359-5914
Just make sure you got proper pulley size so that you don't make too much power and blow your seals. There's another guy on this forum that did that with a D1 and no Meth.
Sup guys What are the pros and cons between the 2 besides 1 makes more boost that the other..does 1 give more bottom end tq,does 1 give more top end at the same boost levels?? Im curious i have a p1 and i wanna step up to the d1
Did the same comparison prior to purchasing a SC. Went with the D1, because my speed shop indicated D1 leaves more room to grow. I could be wrong, but I believe D1 can go up to 900 HP. But calling procharger and telling them what you are looking for is the best alternative!
Kracka (07-27-2016)
