Ysi?
dont give up on your ti-trim just yet. i went 9.19 @ 147 with an old trim in 1900' da. this was in my full weight stock bottom end c5 z06.
Using the formula:
MaxEngineRPM * (LowerPully / UpperPulley) * BlowerRatio = MaxBlowerRpm
or
6600 * (7.75" / UpperPulley) * (3.6) = 52,000
We can see to spin the V3 at it's max RPM at the engine's max RPM, we'd use a 3.54" upper pulley.
The innovator's lower pulley is 7.75" and the supercharger does a 3.6:1 step up. V3 Si and Ti can be spun at 52,000 rpm.
Using the formula:
or
Using the formula:
or
joemosfet (11-15-2016)
When I first inquired about the ysi I didnt realize it was a decent amount of labor. I thought it would be just swapping head units. Not the case.lol
I'm Batman..
Pro Mechanic
3.47" is what I have on my Si trim which put my blower at max output. If you do choose to move forward with the ysi, about how much would you he wanting to sell the T trim headunit for?
So i have a v3 ti trim blower right now and put down about 825rwhp car has run 9.74 in the qtr and consistently runs 9.8-9.9. I already have heads/cam/intake/meth on e50. Ive upgraded the hpfp and injectors as well. Im debating on either changing the pulley on my blower and doing lpfp so i can hopefully run straight e85 or saying screw e85 and running a ysi and c16.
As of now i hate screwing around trying to get my blend right with e85. Its kind of a nausance and never end up with the e50. Its always up or under. E50 which if its over i have to add more 93 since ill run out of fuel. Half the time i end up going to the track with almost a full tank cuz of playing with the blend.
So which direction would be best to go with? Both cost about the same. So cost isn't a deciding factor. With the ysi i will have more room to grow but my goals now are to be around 9.3-9.4 in the qtr. And would like some more torque as well.
Also going with the ysi would i need the lpfp? Or will i be fine as long as im not trying to run e85?
Thanks for any input
not sure on how much i'd sell it for yet. I need to do some research to come up with a fair price.
FYREANT (11-16-2016)
Received 1,762 Likes
I went from 8.9 on a TI to 8.57 with a billet YSI. Intake air Temps are high but going to take care of that over the winter.
#33
I run a 2.7" upper and 8" lower on my ysi. They love to be overspun
#35
Yes i made the switch to the Ysi. I gained a 100whp/tq through the midrange and 65whp/110tq peak. On e35. I really need a lpfp upgrade. Car pulls soo much harder. Can't wait to get to the track and see what she'll do. Hopefully in the next couple weeks ill get a chance.
joemosfet (12-25-2016)
#37
#38
#40
