Piggyback port injection
Nice! Pump gas? Heads and cam car assuming?
Billy@MTI (03-14-2017)
Billy@MTI (03-15-2017)
What happened to this?
Im alittle confused cause in this thread https://www.corvetteforum.com/forums...r-c7z-mti.html
You posted same dyno graph with different mods. Your pics in there doesn't show port setup and only says low side fuel.
Billy@MTI (05-11-2017)
Former Vendor
Damn, Your right!! I posted the wrong graph on this thread. Let me go back and look at the graphs.
for the guys that want crazy power without meth. We add 8 extra injectors and their own ecu. This is the answer!!! We can also add a flex fuel system to it as well. You will be able to run e85 without worrying about have the correct % of e. Send me a message or call me for any questions you may have.
Thanks,
billy
Thanks,
billy
#36
How big of a fuel tank can you put in?
As a straight meth replacement say at 700rwhp what kind of usage compared to meth?
Is there a safety consideration using a high octane secondary fuel regardless if it is needed?
Meth is about $8 a gallon and 5 gallons lasts me about 8-10 tanks of gas so buying high octane gas wouldn't be much different and honestly easier to get.
#38
Former Vendor
We don't use a second tank. This will evenly fuel the car. Meth systems do not fuel all cylinders evenly.
NinjamanZ51 (05-15-2017)
