LT4 Supercharger Compatibility on L86 Yukon Denali
Before reading any of this, if anyone has a thread or article that has someone who is using an LT4 supercharger on a L86 engine in a full size gm truck or SUV, please link post the link. I used the search tab for 15 minutes, and either I am not very bright, or it does not exist.
I just picked up a new Yukon Denali as a daily driver and have been kicking around putting a supercharger on it. I also have a completely bone stock C7 Z06 sitting in the garage that I was going to start to do a pulley, tune, and headers on. I was also going to have a weapon X heat exchanger and thermal plate installed as well, as most already know, the car loses a bunch of power when driving in higher ambient heat.
When I was browsing superchargers on the ProCharger website, I noticed that they make a kit for the Z06. It looks like the kit is only a grand more than the L86 kit, and would allow for much more hp gains than the stock C7 supercharger depending on how crazy I would want to get with it, and would mostly eliminate the heat problems that the stock blower is prone to producing.
From what all I have read, the L86 is the same motor as the LT1 in the stingray and Camaro, with exception to the intake and exhaust manifolds. ADM Performance has a package that puts a LT4 supercharger on a LT1 Camaro. I just have not seen any thread that has a truck/suv with the kit, which makes me think there is some difference in the L86 and LT1 that I am missing. I thought that if installing the bits that would be taken off the LT4 on a L86 is possible, it would be likely someone in this forum would have or known of someone who did it. It just seems to good to be true if this would fit, as it would kill two birds with one stone, get rid of the heat problem for my vette, and allow me to supercharge my yukon for cheap where I could live with the heat issue.
If it is possible, what parts other than my C7 take off parts would I need to purchase to put the LT4 supercharger on my L86 in my Yukon? Any help would be greatly appreciated, as I would like to get this done before the weather turns nice and I can drive my vette!
Originally Posted by Silverboost
There are several guys on performancetrucks.net that have done it. That would be your best bet for info. Sounds like a awesome plan!
OP look up T/A Kid on here. He's done an LT4 supercharger on an LT1, which you noted is essentially the same as the L86.
https://www.corvetteforum.com/forums...-stingray.html
In short, don't bother. The LT4 has different heads than the LT1 and the blower won't directly fit. You'll need to fabricate adapters.
Plenty of turn key S/c kits out there than to hassle with this.
We do offer the adapters to fit the LT4-blowers on the L86.
We just completed a WXM 800hp supercharger package on a 2017 Escalade.
Things you will also need: LT4 DI fuel pump, upgraded in tank fuel pump, S/C main pulley.
Personally, I would put an F1X on the Z06, and swap the LT4 blower to the Yukon. 2 birds with one stone is logical thinking to me!
Can you send me info what I need to put on a 2017 Silverado 1500 5.3
Or does it need to be 6.2?
