C7 ZO6 Procharger 1200 hp front pulley problems
5th Gear
Hi
im new to this forum.
i add to my c7 zo6 many upgrades :
416 strocker short block forged from texas speed
AMP heads
procharger F1X 20 psi boost
on Dynojet (hubs) dayno i have about 1200 Hp
the carnckshaft im using is: Callies Magnum 4.00"
Stroke Gen 5 LT1 Crankshaft, Dry Sump
last night the front pulley (original one ) was cut like u see in the pics
does it happen to anyone ?
any suggestions what to put ?
AMP heads
Tal Ben Avraham (02-20-2017)
Received 1,194 Likes
St. Jude Donor '15
IW or ATI
/problem
/problem
5th Gear
At 20 psi the load on that balancer with a F1X is quite high.
HT
5th Gear
i need it same size as original size
im using today Callies Magnum 4.00"
so its has Double keyway
i waill also need the 2 keyway
im from Israel and im the only one with such car so dont know what to order
thanks allot
Tal
can u tell me what i have to order ?
thanks allot
Tal
thanks allot
Tal
Received 1,762 Likes
5th Gear
im the only stupid one who build something like it here
i spent over 70k upgrades here this car only cost 190k ( we have 200% tax on cars )
believe me if i knew that i need it from the start
it was there
the only problem is because im the only one here with such car so i cant learn from no one mistakes.....
also when i ordered the f1x procharger kit no one there told me i need something ales to change
but thats life
St. Jude Donor '15
At least the crank doesn't look chewed up
I do believe but will look in the AM to verify that the Z balancer hub is aluminum. Not the outer ring but the hub its self. So that would explain the failure. Been about a year since when i took dimensions off it.
I did look at the Z balancer and it is as I remembered aluminum. Only the inner part which includes the crank hub. This would explain the failure and it looking like it does.
bob
bob
