Poll: Which would change driving dynamics of the C7 more: Mid-engine or AWD?
Assuming you like how the C6 handles and that the base C7 would handle similarly...which would more negatively change the driving dynamics of the C7 more...Mid-engine or AWD?
Let's hear your thoughts.
Your thread title doesn't match the question inside your post.
Title: "Which would change the driving dynamics of the C7 more"
Post: "which would more negatively change the driving dynamics of the C7"
Two different questions.
Michael
Michael
I drove a 997 Porsche last night- no where near as exciting as my 08 ZO6 ,felt entirely different but very , very well made... As for AWD, cool but don't do more harm to the steering feel which already doesn't feel as good as the 997
Who cares. You aren't going to see either one in a Corvette.
None of the above.
Low C of G, well balanced 50/50, front to rear, and side to side.
As neutral as possible in cornering balance, none of this built in understeer crap. Flickable, tossable car. Subaru BRZ has this in spades.
The nose should tuck when I lift, and the tail should rotate with a little throttle but not spin tires or spin the car. Neutral balance.
If I wanted more snap oversteer at the limit I'd buy a mid-engine or a 911.
If I wanted it to push/understeer like a truck and I had to use HP and traction to turn, I'd get a AWD.
None of this will matter because only about 5% (maybe 10% if your feeling generous) of all Corvette owners actually ever drive the car at the limits. Taking a on ramp or corner or similar is NOT at the limits.
Auto-x/road course is. So why the concern? Unless, you drive it like you should?
Received 4,376 Likes
AWD will definitely change the driving dynamics more negatively than going to Mid-engine with the engine behind the passenger compartment (the Corvette is already mid-engine, just with the driver behind the engine). Apparently the OP forgets this fact.
AWD deadens steering feel, adds torque steer to the front, increase rotational mass, increases the polar moment, increase steering heaviness. It adds a front weight bias.
Rear mid engine placement removes weight from the front tires for lighter quicker steering, allows more more desireable slight rear weight bias which allows for a 50/50 weight bias under braking for more balance braking; and a rear weight bias for better traction under acceleration. It allows allows a better use of the friction circle of the tires to allow the steering tires to focus their friction on steering and driving tires to focus their friction on acceleration.
Rear mid engine placement removes weight from the front tires for lighter quicker steering, allows more more desirable slight rear weight bias which allows for a 50/50 weight bias under braking for more balance braking; and a rear weight bias for better traction under acceleration. It allows allows a better use of the friction circle of the tires to allow the steering tires to focus their friction on steering and driving tires to focus their friction on acceleration.
http://corvetteactioncenter.com/spec...3/1963-SAE.pdf
They say that a F/R weight distribution of between 47/53 to 40/60
is best, not 50/50.
Mid-engine platforms offer a very different driving experience. Since the vast majority of owners don't track their cars, the way the car delivers the driving experience on the street can be important, and a mid-engine design definitely provides a different experience than the front-engine design.
Tell your wife that the two of you are going to the Black Hills Corvette Classic event for a week, and she has to get everything she wants to take along in a box 12" X 12" X 12".
That's one of the best reasons why less storage space is a good thing; making the wife pack less.
This is the front trunk with a roll-aboard suitcase showing that there is room for it and more in the front trunk:
Here is more luggage space behind the front seats, showing the Ferrari luggage stowed there:
Even though it's a SAE paper from 50 years ago, it is based on engineering knowledge. Very interesting reading.
is best, not 50/50.
is best, not 50/50.
You have bigger tires on the rear! So you want more weight on the bigger tires. This helps take load off the front tires in cornering (less understeer) and braking, and also increases forward traction under power.
The rearward weight bias also allows the driver to rotate the car with the throttle pedal {a)when the driver is skilled, b) when the turn radius is small}.
The lessened weight on the front improves steering feel.
Not disagreeing the the very good description of a mid-engine car.
I think that in practical terms of packaging, layout,etc...the C5/C6 front mid engine layout is best. That and I'm traditional like that.
is best, not 50/50.
is best, not 50/50.
