GM News Today BG Gears up for C7
So, what actually happens when the assembly line is retooled for C7 production this year? Does that mean the assembly line can make either a C7 or a C6 ? I always figured you did one or the other (but I guess I can be surprised--like I was when I found out assembly lines could send cars of different colors through).
Since the exit of the XLR,there is a large portion on the plant that is not being used. Bowling Green will first install equipment in that part of the plant while production of the C6 continues in the old C6 assembly area. Some of that is occuring as we speak, behind plywood walls. This changeover will continue through early in the first quarter. Then the plant will stop all C6 production, while the existing C6 production area is converted to the new C7. When that is done, then the C7 will go into production, most likely back on the old timetable of starting a new model year up in June of each year.
I haven't heard anything about that. But if GM thinks it can come out with another loser(I mean winner), it will try.
Maximize the profit potential of the updated aluminum " Y " platform and the Bowling Green factory
I will go out on a limb and state what I feel is a " no brainer " If Cadillac built an aesthetically beautiful roadster with a strong build quality they would sell well. The Allante was junk and the XLR just wasn't pretty enough.
2015 Cadillac Glamour "V" Supercharged 2+2 "The Most Beautiful Car Cadillac Has Ever Built".
Received 4,376 Likes
What are people smoking? A 2+2 on the C& chassis? If the C7 is just a slightly adjusted wheelbase, that is not going to happen. Are they going to put the seats on top of the transmission? Or is the same space so their heads do stick out the roof, or only be good for people under 4'9"? Or maybe it will be a 2+1 with the one sideways across the car or curled up in the back?
Why do some people think that a rear quarter window means it it is a 2+2? 1979 RX7 had a quarter window, no back seat, the 1970 240Z had a quarter window, no back seat. Fiero quarter window no back seat. The list goes on. Even 1961 Corvetee had a quarter window, no back seat.
What evidence is there that there will be a back seat?
Why do some people think that a rear quarter window means it it is a 2+2? 1979 RX& had a quarter window, no back seat, the 1970 240Z had a quarter window, no back seat. Fiero quarter window no back seat. The list goes on. Even 1961 Corvetee had a quarter window, no back seat.
About as much as there is regarding anything else at this point.........
Even when the XLR was in production, it did not share the same assembly line or area within the plant as the Corvette. The XLR was more of a batch build instead of an conveyor based assembly line. The Corvette is a two conveyor based assembly line configuration. One line was to assemble the drivetrain and suspension on conveyor pallets, and the second line is for assembly of the chassis/body on an conveyor line. At some point, the chassis/body is dropped from the ceil;ing down over the pallet conveyor for marriage of the chassis/body to the drivetrain/suspension and then the car finishes it's journey down one assembly line to the final station where it is driven off under it's own power.
#33
#34
#39
That is the demographic ! How many Females are in Corvettes? Not many. Sure they like them but they would like 2 seater Cadillacs a lot more.
Now I will blur the lines...Where I grew up in Baltimore the SL Mercedes was the car to have if you had a couple dollars, male or female. The latest gen MB SL ( 2013 ) is $100,000 and not pretty .
Cadillac's time has come !
#40
