My Wishes for the C7
I really think many people are way off in their thoughts as to how the C7 will look,but I don't believe they will be so radical,that people will be turned off.
I for one would like to see the weight reduced to no more than 2800 lbs.The benefits would be noted throughout. The handling,braking,less weight=more hp and for those that take long trips,better mpg. The rear hatch window could be made smaller(narrower).
I would like the fob improved.
I would like the seats to give more lateral support.
Better sound insulation and heat reduction(console).
It would also be nice to order options w/o having to buy at a certain level to obtain it,such as 1LT,2LT etc.
These are my wishes and thoughts.
First I want to see a GREAT looking car, performance to match the look and exceed the competition. Ala carte options, naturally an improved interior. I also want this car to do what the Z06 did, make the europeans catch up!
You want a heavier seat, more weight adding sound and heat insulation, and then take 400lbs off the car after adding 150lbs to it in the 1st place?
Do I have that about right?
Cause I didn't know that fairies and gnomes would be the one's building the car......
So if this car is being built in never never land.....then I want them to do away with the mechanical clutch......and in it's place I would like a magnetic particle clutch. So I can launch it as hard as I want, slip it at high reves all day long, and it will never wear out. It will even easily handle the extra 500hp that I'll be adding in modifications to the already fully forged motor that awaits my genius
There "base car" is already fully optioned out at $75k you then delete things you don't want to lower the price for what you're willing to pay......you know just backwards of the way it's done now.
I would love the following.. and it's not too much to ask!
Updated exterior design - cutting edge gorgeous looks
Current chassis with refinements
Current LS3 with direct injection
Updated interior similar to Cadillac standards w/ CUE
Dual clutch transmission
This would be minimal cost to GM and make me put my deposit down yesterday
Let me see if I understand you correctly.
I believe you can get more lateral support without increasing weight. Insulation doesn't weigh anything. Keep your unintelligent comments to yourself as it doesn't reflect highly of you.
Now this can be done very easily.
Where did you get 2800 lbs from??? Besides the Corvette is pretty light already. It will never get that low, I'd be happy if it's 100 lbs. lighter.
What I wish is, not in any particular order:
1. Far superior interior
2. DCT
3. Seductive styling
4. Better dealer service & experience
5. 4/48 warranty
6. 475 HP+/460 TQ+
7. Creak free
8. quiter cabin
9. Better steering
10. Better tires and launch system
11. Make improvements and evolve the car faster (do not let it get stale). Not like they did in the past like wait till the last year to slightly improve the seats or still have an outdated Nav. system or lag on putting LED's. I bet had they spent a little engineering cost and put LED's on the car say starting in 2010 the sales #'s would have been higher just for that reason. Everyone else was updating their cars so not fall behind but GM doesn't do that and that is one of the reasons they fell behind in the first place. But I think the new GM has woken up and finally gets it.
None of the above is too much to ask for and should be a given in this day & age. They can increase the price if needed but GM should not short change the Corvette anymore.
2. DCT
5. 4/48 warranty
6. 475 HP+/460 TQ+
7. Creak free
8. quiter cabin
9. Better steering
1. Better quality
2. 4th, 5th and 6th gear ratios that improve acceleration, not MPG.
3. Offer an option with minimum trim level without "luxury" stuff like heavy leather power seats, radio, gps, noise insulation, etc.
2800 lbs is S2000 territory. Sorry, not going to happen anytime soon.
They offered 3. in 1999 and 2000 with the FRC, which evolved into the Z06. If you want a stripped Z06, ain't gonna happen. That would be attractive to a very limited audience and not worth producing.
Yes, I know the GT3 RS. And yes, quality and devoid of amenities CAN coexist. I took quality in a different context. My bad.
There were 518 Z06s built in 2010 and 904 Z06s built in 2011, and a bulk of those are happily driven on the street. f you believe GM is going to gut a car like the Z06 and offer it as a separate model to sell 100 or so annually (a guess on my part - 200 maybe), think again.
Your post was your wish. I understand that. The business factors to support a decision to build such a specialty car in these times is flimsy in a corporation the size of GM. A niche manufacturer like Porsche can offer those types of specialty cars.
Received 4,375 Likes
Easy...
500hp
Upgraded interior
and put the power to the ground more effectively (i.e. more grip off the line / less wheel spin)
If the C6 ZR1 was able to put power to the ground more effectively, performance wise, it would be second only to the Bugatti
500hp
Upgraded interior
