C7 a wide body or not?
The 370 Z has a interesting B pillar / quarter window arrangement and it seems to work
I saw where keeks mentioned the C7 quarter window and they stay in place. I hope they are not completely blocked by the " halo bar ".
Well, the real issue remains is the C7 a wide body or not? I'd say so based on what speculative comparisons we have at this point.
Below are the images from Trinity. I complained to them about the first set of these images because there was a lot of distortion. Jim agreed and they re-rendered them and reposted them yesterday. All I did was crop down the original in Pshop to show the GS next to the C7.
First version...
Latest version...
Here is what Jim said about this process...
If you have any more questions or complaints about the image, go ask Trinity.
First version...
Latest version...
Does your friend have any actual, factual measurements of a C7 to base his comparison on? Assumptions on his part, or yours, is not enough to compare the sizes of the two cars.
In my opinion, if anybody wants to invest the time in this type of measurement you are MUCH better working from "spy" photos such as those from Car and Driver rather than a rendering. If you can find a known item to measure (i.e. lug nut cross section) then you can use that to scale the part of the photo that lies in that plane and perhaps work from there.
Personally, I can wait until the real thing is released and I don't get trying to extrapolate measurements using a computer generated model based upon a previous rendering based upon a recollection based upon a .... etc.
The C6 is still being seen at a different angle than the C7. I'd want to see the two cars from the same perspective, e.g. standing between them not directly behind one or the other; or two separate shots, directly behind each. And a straight-up overhead shot would be much more informative about overall width.
But ultimately you're looking at a guesstimated rendering of C7, not something based on the real C7's dimensions, and trying to calculate whether there are a couple of inches this way or that. "Measure" away, but I wouldn't put much stock in the results.
I'll guesstimate with a completely different approach. We believe GM wants to reduce apparent width, and probably apparent size overall. Also, frontal area significantly impacts highway fuel economy and top speed. The widebody look is appealing to existing Corvette fans, but they can accomplish that to some degree with styling as opposed to adding inches. And between weight reduction and possible improvements in tire technology, they can achieve better handling without GS/Z06 tire widths, which can also benefit rolling resistance thus fuel economy.
I bet the car is about the same width as the base C6, but manages to look like the wheels are set wider like the GS/Z06.
.Jinx
.Jinx
I hope you are right Jinx
I know I might catch some heat for this but my ZO6 always felt like too much car for the back roads , kinda taking the fun out of some spirited driving. I would love the C7 to be more nimble.
He's not my friend, I just sent him as message as can you. Everything you, me or anyone talks about here on C7 Forum is assumption, yet comparisons are the daily occurance.
Close inspection of the C7 model has produced good things so far. I think the closer we look at it and the more tweaking Trinity does the more real-looking it gets. And I bet the more like the real thing, too, assuming the basic elements are right. So by all means, poke and prod and measure away; accurate or not, it's interesting.
.Jinx
.Jinx
Received 4,375 Likes
Placing a straight edge on my flat sceen monitor, I see the C7's top is 10% wider then the C6's. My C6 top measures 46" wide, so adding 10% means the C7's top is 4.5" wider.
I doubt that the C7's roof is that much wider then the C6's roof. I don't think the two cars are sized/scaled correctly when they did the photoshop.
BlueOx the reason this matters to if it is a widebody or not is that if you took 6" out od the middle of the rendering, it would not look any where near as wide as it does somared to the C6 GS shown.
so yes getting the two cars in exactly the same scale is really important to being able to tell if it is a "widebody" what ever that really means.
First version...
Latest version...
First version...
Latest version...
#34
.Jinx
that's a real horoscope for today, honest
#35
I would suspect the C7 will be about the same width as the C6, as they are trying more to play to a world market, cafe etc. I think they have just incorporated the width of the C6 flares protruding from its body into the entire body of the C7 falling to about the same measurements edge to edge. So in ways the body will be somewhat wider while still falling within the same width footprint of the C6. I'll bet that overall length of the body is shorter though, whie having a longer wheelbase.
Putting the two side by side though is really starting to show hs the C7 is going to quickly make the C6 outdated. And despite what many seem to think, I feel the new taillights destroy the oversize boring round lights of the C6 by a mile. I'm still going tour pedict that most are going to respond positively to this car when released. I'll be surprised if they don't
#36
Here is my logic:
C7 Base (as we have seen it): Yes, wide body, unless they come out with a mid year cycle refreash that appears wider. I doubt it.
C6 GS/ZO6/ZR1: Yes, wide bodies
C6 Base model: No, not a wide body because when compared to the GS/ZO6/ZR1, they appear narrower.
C5 Not sure how to judge the C5, but I would say they all appear wide to me. Can't get that booty out of my head when I think of the C5.
You cannot cross shop the C7 with different corvette generations to determine if it (the C7) is a wide body or not. You have the compare the model line up within it's own generation. Talk to me in 5 years or so and I can then tell you if the base C7 is a widebody
#38
perhaps our screens display differently or we took different points as the edge. I measured the C6 roof at 1 3/8 versus 1 5/8s on a ruler that measured to 32nd of an inch. I get a difference between 18 and 19% hence my 6-8 inches. Doing scale work off a screen is difficult at best.
It is all about perception. I mean, is it really absolutely necessary for the C7 to be wider than the GS to look like a widebody? To me the apparently lower roof and wider hips with no fender flares just gives that widebody perception.
I guess if 6" were taken out of it, it would appear completely different. That is why talking to Jalopnik or Trinity about apparent size would tell you more.
#39
I don't see any reason why they would widen the roof panel that much so I'm chalking it up to the rendering being off vs the Z06's photo. Since the person that made the C7 rendering has absolutely no actual measurement of the C7 to use as a baseline, the photo of the two cars side by side is meaningless, thus it is impossible to draw any conclusion as to whether the C7 is a "wide body" or not. It's like looking at the moon in a photograph with a 747 flying in front of it and then trying to calculate the diameter of the moon based on the known dimension of the 747.
#40
I don't know how you can say that. Supposedly, the Jalopnik guys were with the cars for 7 hours. That is a lot of time to take measurements or to at least take detailed photos with some sort of scale in them. It would have been very easy to measure wheelbase & track width, etc., etc.
