Possible C7 component leaked! ...with pic!
Not sure how long until the GM police force this to be taken down, so take a good look!
Does the "1/2" etching indicate a major change in the handling?
Could this indicate AWD?
If they actually use these lugnuts, is the C7 DOOMED?
Received 5,290 Likes
Those are Camaro lug nuts!
Does the Camaro have 1/2" diameter studs?
I can tell by the reflection of the photographer in the lug nut that 70% of the vehicle will be made from chinese parts.
I can tell.
I can tell.
Yep - as I predicted...ALL titanium!
It's been some 12 or so years since I've had one of my knock off wheels removed from my C2, but them "adapter" nuts sure looked like lug nuts to me. Even used the same lug wrench to tighten them that I use on my 56.
Received 1,293 Likes
Unmodified C8 of the Year 2021 Finalist
2018 C7 of Year Finalist
*When does NHTSA recommend that tires should be replaced?
While tire life will ultimately depend on the tires’ service conditions and the environment in which they operate, there are some general guidelines. Some vehicle manufacturers recommend that tires be replaced every six years regardless of use.* In addition, a number of tire manufacturers cite 10 years as the maximum service life for tires.* Check the owner’s manual for specific recommendations for your vehicle. Remember, it is always wise to err on the side of caution if you suspect your vehicle has tires that are over six years of age.
