exhaust valves ???
Both the exhaust and intake valves (totally different ) are described in detail in some of the material set forth in some threads here. In both instances they are multi-part valves comprised of different materials.
The LS6 which has the same basic setup never had this issue. So, it could be the valve guide wear on the LS7 was what ultimately resulted in the valve failures in the LS7 engines.
The Consigliere
Received 5,447 Likes
Yes, sodium filled hollow exhaust valves. Just like current Z and ZR. And the new Viper. And other high performance engines.
It has to be the valve or the guide. There's no possibility of any z06 failures could result from driver error from over revving the engine, no possibility any of those failures would have been prevented by an automatic tranny that can't be broken by an inadvertent downshift from 5th to 2nd at 140, no chance at all of that.
