A little more info on GM's new engine line up for the trucks, EcoTec3
Old 12-14-2012, 11:33 PM
  #41
CPhelps
CPhelps's Avatar
Originally Posted by FRANKENSTEIN4x42000
The hp rating on the "new" 4.3 is 260 so yes i did make a mistake on the hp i thaught the Ford base engine was the eco boost at 360hp. the new 5.3 is 330 with DI and DOD or whatever you want to call it, I still by my post it's a joke. And if you think about it that's all they can do the mighty Corvette LT1 is 450 and it's a 6.2 so there is no way they will have more hp than that.
Why is new in quotes? It has a different block, camshaft, crankshaft, heads, pistons, bore, stroke, direct injection system, and intake manifold, how is it not new?
Old 12-15-2012, 03:33 AM
  #42
Jinx
Jinx's Avatar
Maybe the plastic in the intake is recycled from old Vortecs
Old 12-15-2012, 07:53 PM
  #43
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
Originally Posted by NSC5
From GM's media website, "All engines feature an engine-driven mechanical vacuum pump to enhance braking performance"
I imagine this is the mystery pump.
Since they are moving to electric type power steering that removes the need for a PS pump to provide for the hydraboost braking used on some models.
I bet you're correct on it being a vacuum pump. The photo's of the Vette versions don't show the pump.
Old 12-15-2012, 11:42 PM
  #44
LS1LT1
LS1LT1's Avatar
isn't the C7 450hp?
I don't know, is it?
I suppose it could be only 450 but it might even be 470 or even anywhere in between.
The final figures haven't been released yet.
Old 12-16-2012, 12:35 AM
  #45
obzidian
obzidian's Avatar
St. Jude Donor '09
Haters will do what they know best....
Quick Reply: A little more info on GM's new engine line up for the trucks, EcoTec3
