C7 M7 and CAGS
Old 01-19-2013, 08:17 AM
AFVETTE
AFVETTE's Avatar
Default C7 M7 and CAGS
Does the C7 M7 have CAGS?
Old 01-19-2013, 09:35 AM
4GS7
4GS7's Avatar
Hopefully AFM and the new 7 speed have removed any need for CAGS.
Old 01-19-2013, 09:39 AM
sprtplt
sprtplt's Avatar
It probably locks out second through fourth now!
Old 01-19-2013, 07:42 PM
Rubber Ducky
Support Corvetteforum!
Rubber Ducky's Avatar
Zero mention of CAGS in anything released or discussed on the C7. Strongly suspect the ECO mode and the 4-cylinder mode clear the gas-guzzler hurdle without CAGS. Bet it ain't got it.
Old 01-19-2013, 08:17 PM
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
The new .42 7th gear doesn't help the city gas mileage whereas the 1X4 CAGS does. I also doubt if the AFM will have the car running on 4 cylinders when accelerating in first gear from a traffic light in traffic in the city.
Old 01-19-2013, 10:35 PM
_zebra
_zebra's Avatar
4th is still 1:1 & the 4cyl mode is for cruising, so realistically, it should still drive around town about the same as ours now
Old 01-20-2013, 08:27 AM
Rubber Ducky
If C7 does have CAGS ... you're right. Bet not.
Old 01-20-2013, 09:25 AM
Raitzi
Raitzi's Avatar
It still has CAGS at least for US market. (It was on motortrend or car&driver)
Of course there will fix for this.
Old 05-04-2013, 11:09 AM
rsmarti1
rsmarti1's Avatar
I've read (somewhere) that the CAGS would be overridden in "TRACK" mode and am wondering if this is true?!
The other (MAJOR) concern I have is if CAGS is defeated by other means (fuse or plug replacement, etc.) by the owner that the warrantee would be invalidated. True?
Old 05-04-2013, 11:35 AM
msm859
msm859's Avatar
Easy fix. Drive moderately and it will never engage. After 3 Corvettes with it, I would say it would shift 1-4 maybe 1 out of 200 times and then I would usually just put it in 3rd. No big deal.
Old 05-04-2013, 11:39 AM
1BADLS3
1BADLS3's Avatar
Are all C7's going to have AFM, or just the ATs? Reason I ask is the Camaros with the 6.2L/AT have AFM, but the 6.2L/MT do not.
Old 05-04-2013, 01:59 PM
TorqueDriver
TorqueDriver's Avatar
The C7 M7 does have CAGS. At the bash seminar - someone in
the audience asked if it could be defeated like with the C6, and the speaker declined to answer that.
The C7 M7 does have AFM.
Old 05-04-2013, 02:52 PM
Jinx
Jinx's Avatar
CAGS works while accelerating; AFM should work while at a steady speed.
Leave from a stop, CAGS puts you into fourth, reach the speed limit, AFM puts you into four-cylinder mode, where you stay until you come to a stop again. Lather, rinse, repeat.
Now if they added stop/start, they could save you the fuel wasted waiting for that next green light.
Old 05-04-2013, 02:58 PM
themonk
themonk's Avatar
Location: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
Received 1,456 Likes on 799 Posts
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
nope, first to seventh all the way baby.
Old 05-04-2013, 03:17 PM
Zymurgy
Moderator
Zymurgy's Avatar
Received 15,075 Likes on 6,173 Posts
Does McDonald's have golden arches (Sedona, AZ excepted)? Yes it has CAGS.
Old 05-04-2013, 03:26 PM
Jinx
Jinx's Avatar
With C6 they got the CAGS algorithm refined to the point that it's seldom a bother, and easy for the driver to learn slight behavior modification to avoid it if he chooses. I expect the same for C7. I also expect the same resistor fix will be available for those who prefer to kill it. After all, why would GM fix what ain't broken?
Old 05-04-2013, 07:47 PM
JerriVette
JerriVette's Avatar
Received 3,948 Likes on 2,177 Posts
Are there really corvette owners who shift out of first gear before 25 mph?
To C7 M7 and CAGS
Old 05-04-2013, 08:07 PM
ZL-1
ZL-1's Avatar
Yes the C7 does have Cags. As for AFM, the 4 cylinder mode won't occur in 1st, 2nd, or 3rd. It's only enabled in 4th, 5th, 6th, and 7th, and only if you turn the mode switch to the left from its default position to the ECO setting. It won't work in the Tour, Sport, or Track setting.
Old 05-05-2013, 02:43 AM
TorqueDriver
It seems that AFM does in fact activate in the default touring mode.
It just operates to a much higher level in the ECO mode.
Chevy describes the C7 default (normal) touring mode as having adaptable power with V8 during acceleration and V4 AFM during coasting.
From the Corvette Museum C7 specifications listing:
Active Fuel Management: in normal mode, the LT1 engine uses V-8 power during acceleration and V-4 power when coasting; in Eco mode the engine remains in V-4 mode to improve fuel economy until aggressive acceleration is needed.
Old 05-05-2013, 12:33 PM
RC000E
RC000E's Avatar
To be clear, powertrain engineers said they could eliminate cags if certain govt regulations changed governing required shift point speeds. They said the regs were written in the 70's when trannies were 4spds...now with 6 and 7 spds...they have to have cags to conform to these ridiculous regs.
They wholeheartidly said, "if we could take it out and legally sell the car, we would."
Quick Reply: C7 M7 and CAGS
