Tadge explains why 6 vs 8 speed auto...
Old 01-23-2013, 01:20 PM
Raitzi
Raitzi's Avatar
It is not the number of gears what matters, it is rev matching and shift speed. If automatic C7 is not faster than manual, we can call it a failure.
Old 01-23-2013, 01:21 PM
Parker Corvette
Parker Corvette's Avatar
DRC--- A person can post a message very clearly and yet it seems people don't read it or don't understand it. In my post #9 I clearly said that me Z4 runs at 2,000 to 2,300 at 70 MPH. I do not drive a Honda S2000. My Z4 does not operate at 8 or 9,000 RPM. My Z4 is in storage at this time, but I will check my rpm's at 70 MPH the next time I get it out.
Why is it that GM seems to be one of the few without an 8 speed auto tarns? Most premium brands have an 8 speed auto. GM's Cadillac XTS does not. Everything else in the XTS is new and very nice. GM just simply didn't get it done. The mags are bringing up the lack of an 8 speed.
Old 01-23-2013, 01:22 PM
BeaZt
BeaZt's Avatar
St. Jude Donor '14
So what exactly are they not getting done?
Old 01-23-2013, 01:23 PM
Parker Corvette
My old (traded it off) 2009 C6 and the wifes currect 2008 C6 both got 28 to 29 mpg. Where is the improvement?
Old 01-23-2013, 01:25 PM
Raitzi
Raitzi's Avatar
Ford is developing the 10 gear automatic for GM and Ford 2wd cars: http://www.autoblog.com/2012/10/01/f...eed-gearboxes/
Kappa
Kappa's Avatar
My 2012 BMW Z4 with the 4 cyl turbo engine and 8 speed auto trans runs about 2,000 to 2,200 RPM at 70 MPH. It is not "wound up" by any means. When I go from comfort mode to sport the RPM's increase about 300 or so. On a recent rally of 200 to 300 miles all of it at altitude, I got around 40 MPG. That's one of the benifits of an 8 speed auto transmission. Of course the Vette doesn't need no stinking 8 speed. That's good because you don't have one avaliable.
GM is behind the 8 ball once again.
Vehicles that currently have an 8 speed auto transmission include. BMW 5 6 and 7 series. Lexus LS series. BMW X5. Jaguar F roadster 8 speed auto. INfinity IR G coupe 7 speed auto.
If you don't have an 8 speed auto, and ev erybody else does, then you have to say something like we don't need it.
I told you this already, none of those companies makes their own transmission. Most, if not all of them are using ZF and Aisin transmissions. The cost/benefit ratio obviously did not impress the Corvette team enough to buy one of those transmissions and try to fit it in a rear transaxle car.
A lot of programs got put on hold or canceled during GM's reconstruction. The 8 speed auto was one of them. That being said, I'll be surprised if its not in the new CTS coming out this spring.
Old 01-23-2013, 01:26 PM
Parker Corvette
When you don't have an improved transmission to offer on your brand new car, you tap dance.
I Bin Therbefor
I Bin Therbefor's Avatar
Default Interesting
Originally Posted by DRLC5
Also the he said they cant find an auto trans that can plug and play with Corvettes HUGE amount of torque? I thought it was 450 lbs of torque? I see several automatic trans handling much more torque than 450 my CTS V for one? Unless it is a fitment issue or maybe it will have much more than 450lbs of torque?
The trans for the Corvette mounts to the front of the rear axel. What is needed is a transmission, in production, that can handle the torque and that can be mounted in that position. From "All Corvettes are Red" you'll learn that a transmission that is designed for four wheel drive meets the mounting requirement with minor mods. So, GM needs to have a four wheel drive automatic transmission in production that can handle 450 lbs of torque and better that the Vett team can modify for Corvette use. The RPM range of the transmission must also meet the LS1 needs. I keep saying in production because the Corvette can not afford to develop a unique transmission. I am not aware of any such four wheel drive intended automatic transmission that GM has in production or coming. Perhaps the transmission wars that he mentions will lead to such a development.
chiromed0
chiromed0's Avatar
Yes! At least my tranny isn't out of date! Just my car.
Seriously, 99% of my driving could be done in just 2nd gear. They could have a direct drive and I wouldn't even notice.
I noticed in the 7 spd DCT it tends to jump all over the place. You can't feel it but man it must wear out parts quicker with so much going on.
BeaZt
BeaZt's Avatar
St. Jude Donor '14
There's tons of other improvements and we don't know for a fact what the MPG will be until real users get them on the road.....and great MPG in a Corvette is just "low hanging fruit" if you will...IMO all other performance aspects take precedence. It would be odd to hear that someone bought a Corvette only because it got great gas mileage.
Old 01-23-2013, 01:28 PM
BeaZt
BeaZt's Avatar
St. Jude Donor '14
While still beating you to the finish line
jimmyb
jimmyb's Avatar
Received 4,248 Likes on 2,023 Posts
Originally Posted by FASST LN
While he dismisses the 8-speed auto and states the 6-speed auto is sufficient, then how could he also support their decision to abandon the 6-speed manual to go with a 7-speed manual?
Apparently they feel more gears are better if you look at the change to the manual transmission. It sounds like he's just covering for GM not having a DC or new/better offering for the automatic over the existing A6.
Anyone know what the shift times are for the A6 in the C6? I wasn't aware there was an improvement to such in 2012.
I agree. You can't brag about the NEW 7 speed manual and 2 minutes later say there's an "marketing arms war" in regards to the number of ratios. That said, I think the A6 is plenty for an engine with the LT1's torque curve.
I do wish he would just say what we all KNOW, that the GM 8 speed auto isn't ready yet.
In the end, I will order a manual (like always), but the automotive press sure didn't do him any favors with the Aisin 8 speed auto rumor, since almost 3/4ths of Corvettes are ordered with automatics.
Jimmy
Old 01-23-2013, 01:34 PM
  #33
Raitzi
Raitzi's Avatar
According to the link I posted the next one will have 10 gears not 8.
  #34
BlueOx
BlueOx's Avatar
When your car is a weak kneed 4 banger your wife made you buy, you whine about 8 spds.
Old 01-23-2013, 01:35 PM
  #35
Bill17601
AIR FORCE VETERAN
Support Corvetteforum!
Bill17601's Avatar
With big torque you do not need more gears. The drag racing Corvettes use the 4 speed automatic. My C5 equipped with 3:15 gears, an LS3 and four speed automatic has not lost to a 6 speed automatic Vet. But I have not raced yours so I concede yours is faster before you tell me that. I run on the street heads up for money so your not going to get me to tell you my et. Great interview thanks to all who brought it to this thread.
Old 01-23-2013, 01:39 PM
  #36
DRC
DRC's Avatar
I understood your point, and I also made a little joke, no bad intentions.
But, Tadge was quite clear I thought, said an 8 speed is heavier, costlier, and in testing suggested the 6 speed held up better, said with a wide band of torque the 6 speed did the job well.
GM just simply did not get it done? Good Lord buddy, aluminum frame, carbon fiber hood / roof, all info suggests the most fuel effecient 450 HP (maybe more) engine in the world, launch control, take it to the drag track of road race track, beat the crap out of it and your 100,000 mile warranty is in tact, probably costs in the mid 50's, etc., etc.
Get a piece of paper and a pencil and make a list of all the cars on the planet that accomplish the above. Hint: You won't need a very big piece of paper.
Old 01-23-2013, 01:40 PM
  #37
BeaZt
BeaZt's Avatar
St. Jude Donor '14
The Chevelle still has a power glide...so do Top Fuel Dragsters..lol..don't need any stinking extra gears..hey is that a gas station over there? LOL
To Tadge explains why 6 vs 8 speed auto...
Old 01-23-2013, 01:42 PM
  #38
DRLC5
DRLC5's Avatar
It is out there already and if they mass produced it the cost would go way down. Actually it is not much more than the current trans if we has a buyer had to go out and buy. Redline just installed one in a 700rwhp ZR1?
Old 01-23-2013, 01:53 PM
  #39
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
Originally Posted by BlueOx
Hmm...my old '05 runs at 1450 rpm at 70...while I get a consistent 28-30 mpg. Tell me again why we need an 8 speed in a C7 that has at least 50 more hp and a whole lot more torque that will get even better mpg?
That's odd. When I do the math on a 2005 C6 with 285/35ZR-19 rear tires and the A4 with .7:1 overdrive 4th gear and the base 2.73:1 differential gear I come up with 1675 RPM at 70 MPH.
The optional 3.15:1 ring gear and pinion in a 20 equates to 1930 RPM at 70 MPH.
The 2006 A6 with it's .67:1 6th gear overdrive and standard 2.56 rear gear sees 1500 RPM at 70 MPH.
1450 RPM in a 2005 C6 with the A4 and base 2.73 rear gear equates to 60 MPH.
I sometimes wonder if you really do have a Corvette, or just pull crap off the Internet to post.
You can bet that a 8 speed auto will run at lower RPM at a given speed then your A4 or the newer C6's A6, while delivering better gas mileage.
My 505 HP 7L C6 will equal your 400 HP 6L C6 in highway gas mileage. But then I have a 6 speed with a higher final gear ratio(1.71:1) then your C6(1.91:1 or 2.45:1).
That's what a 8 speed auto will bring to the table over a 4 or 6 speed auto, plus the lower gears in 1 thru 5, will give better performance.
Old 01-23-2013, 01:58 PM
  #40
BlueOx
BlueOx's Avatar
Hmmm, never found that link yet huh?
I have a 6 speed manual 3.42. I was making a point about torque and the relative lack of need for an 8 spd, even in my old LS2. So what rpm will the LT1 in the C7 run at 70 mph with the 7 speed manual? How about the 6 speed auto? The 8 speed auto?
Mr.z4 runs at 2200rpm with his 8 speed at 70. I consider that high.
Quick Reply: Tadge explains why 6 vs 8 speed auto...
