Projected C7 Performance
Old 01-28-2013, 10:37 AM
BWF07
BWF07's Avatar
St. Jude Donor '11
Oldtimer
Default Projected C7 Performance
I realize we don't have any real data to go by, but based on what Tadge said a few weeks ago we can expect the C7 to do 0-60 in less then 4 seconds.
Now here is the question, the 2013 GS turn the 0-60 in 4 seconds flat. What are your expectations on the 0-60 time in the C7. Also what about 1/4 mile times? Again the GS is rated at a 12.3 @ 115.6 MPH
I am thinking maybe a 3.8 in the 0-60 and for the 1/4 mile 11.9
Old 01-28-2013, 10:44 AM
billythekid310
billythekid310's Avatar
Now here is the question, the 2013 GS turn the 0-60 in 4 seconds flat. What are your exceptions on the 0-60 time in the C7.
I am thinking maybe a 3.8.
You mean expectations...
I'll be bold and say 3.7...
Old 01-28-2013, 10:48 AM
BWF07
BWF07's Avatar
St. Jude Donor '11
Oldtimer
Yes I did thank you.
Old 01-28-2013, 10:51 AM
Zymurgy
Moderator
Support Corvetteforum!
Zymurgy's Avatar
Received 15,075 Likes on 6,173 Posts
Old 01-28-2013, 10:54 AM
lt4obsesses
lt4obsesses's Avatar
Well, the 0-60 is only one very small number in the performance. The real performance bump is going to be the ride and handling. With the stiffer frame and stronger yet lighter suspension parts, add that the weight has been pushed lower and centered in the car, this thing is going to glide on rails.
What all of that means, for those that are disappointed with the estimated HP of this car, is that you will get to actually use more horsepower than on the previous car. It will feel like 500+ ponies. I think that is going to be the real difference in this car.
Old 01-28-2013, 10:55 AM
bigterpsfan
bigterpsfan's Avatar
That would be C6Z territory. Unless they seriously underestimated HP or exaggerated weight OR newer technology allows them to put the power down MUCH more effectively (more likely scenario) then no way. I actually hope that it is the latter and you are correct. That would mean a C7Z with similar technology would run low 3 seconds right along with the C6ZR1, with less HP.
Old 01-28-2013, 11:35 AM
Flex182
Flex182's Avatar
3.7 with a good driver.
Old 01-28-2013, 12:10 PM
QUAKEJAKE
QUAKEJAKE's Avatar
GM'S number will be 3.85
Old 01-28-2013, 01:50 PM
4GS7
4GS7's Avatar
0-60 times are useless when you get into cars that are traction limited. Look at 1/4 mile and trap speed.
Old 01-28-2013, 02:05 PM
BWF07
BWF07's Avatar
St. Jude Donor '11
Oldtimer
They may be useless, but almost every manufacture post them as well as every automotive magazine. I believe a lot of people use it as a way of measuring different competitors.
I suppose I could have including projected 1/4 mile times also.
Old 01-28-2013, 02:10 PM
Mr.Chevy
Mr.Chevy's Avatar
I hope we will 3.7 and 11.7 +124mph
Old 01-28-2013, 02:23 PM
BWF07
BWF07's Avatar
St. Jude Donor '11
Oldtimer
That is what the Z06 is doing, so that may be a reach, but then again we really have no idea until they start production of the actual car.
Old 01-28-2013, 02:28 PM
DREAMERAK
DREAMERAK's Avatar
St. Jude Donor '12-'13-'14, '16
Originally Posted by Zymurgy
3.9+
GM says 3.95 for the Grand Sport, so that wouldn't really be an improvement, Tadge said the Stingray woluld be faster than the GS.
Old 01-28-2013, 02:54 PM
Raitzi
Raitzi's Avatar
Could do close to that with automatic.
Old 01-28-2013, 03:02 PM
BeaZt
BeaZt's Avatar
St. Jude Donor '14
The torque on the low end is supposed to mimic the LS7, i'd go with 3.7 0-60 and a mid 11 1/4mile
Old 01-28-2013, 03:07 PM
Jim Barker
Jim Barker's Avatar
I had a 08 with duel mode opt 2.73 and auto. Now have GS A6 and I dont see how this heavier car is faster than base with same motor. It stops better and corners better but how do you carry all the extra weight and get down the 1/4 mile better? Haven't taken the GS to the track yet.
Old 01-28-2013, 03:10 PM
AFVETTE
AFVETTE's Avatar
It'll slot between the Z06 and GS. That's a no brainer.
To Projected C7 Performance
Old 01-28-2013, 03:13 PM
Zymurgy
Moderator
Zymurgy's Avatar
3.94 is faster than the GS and is still 3.9+.
Old 01-28-2013, 03:17 PM
tuxnharley
tuxnharley's Avatar
Received 1,939 Likes on 1,185 Posts
Torque is the major factor in low speed acceleration (assuming you can get it to the ground), so I'd think the C7 would be better than the GS and close to the C6Z.
Old 01-28-2013, 03:20 PM
DREAMERAK
DREAMERAK's Avatar
Technically your right, but do you really think GM would do that?
Quick Reply: Projected C7 Performance
