CAGS Eliminator for C7?
I bypassed the CAGs on my 2009 Z06 using the same identical aftermarket $20 eliminator that is used on the C6's built before it. I did not purchase a $1500 OEM part to bypass my CAGS.
Unplug the electrical connector at the transmission, insert dummy plug into the transmission to keep dirt out, and plug the eliminator into the wiring harness from the computer. The eliminator is nothing more then a 2.2k ohm resistor mounted in a GM connector, so it is a "plug-and-play" unit.
Dodge viper through 2008 can be bypassed just as easily as the current vette but the buck stopped in 2009. I know based on personal experience.
Pretty sure this is what will happen with the new vette.
Received 3,844 Likes
"Ask Tadge" Producer
Well good for you. Now, if you only read carefully, you would notice I was referring to 2009-2010 and current DODGE VIPER, not corvette.
But of course, GM will go against emission standards unlike Chrysler, apparently this is why AFM is there
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
However I never felt the need for an eliminator. The way I drive, the skip shift was never activated.
jas
Gen 4 Viper and C6 08 on use the same t6060 tranny. And again, this is not about difference in drivetrains, this is about methodology used to comply with emissions regulations. Seems to me Chrysler did it sooner than GM but in the end, GM will follow because there is only a limited number of technologies available to make our government happy. If this is above your head, I may include some pictorials to help you understand.
If GM wanted to prevent defeat of CAGS by owners, they would have done it well before the C7 intro. It is there to game the EPA test protocol that determines the fuel economy numbers. Unless the Feds dictate otherwise, GM doesn't care if owners defeat CAGS. JMHO.
Unless they change the way they do it, all you need to defeat the CAGS is a blown smart fuse. I replaced my CAGS fuse with a blown smart fuse over 20K miles ago with no issues.
#33
Platinum Supporting Dealership
#37
Yep; we're not talking about the Gen 4 Viper and the Gen 6 Corvette. We're talking about the Gen 7 Corvette. You had to inject your knowledge of the Gen 4 Viper into this discussion and it has not had any bearing whatsoever on Corvette's development.
You're making an assumption based on absolutely no knowledge of coming laws, regulations, rules, etc. Because one manufacturer does it, all will?
Thus far you've not proven me wrong on anything I've said, you've merely diverted the conversation. And then you have the temerity to call me stupid? Careful there, son.
jas
jas
#38
jas
jas
Now, son, do you actually have a proof CAGS can be disabled on C7 or are you talking out of your behind?
#39
I do hope it is defeatable. My dealer kindly moved my eliminator from my Z06 to my ZR1 when I bought it.
I have found it is very easy to get hit by it on a left turn from a stop when you have to roll out of the case after you take off because someone slows in front of you, or for other reasons. It's most annoying and I'd prefer not to have to remember to make sure it is going x MPH before I shift for 2nd.
#40
