CAGS Eliminator for C7?
#42
#45
This still will trip CEL on 09-10 viper. Before you and others jump on corvette not being a viper, please try to understand viper example is only used to demonstrate this can be done by the manufacturer. Until someone gets a C7 and successfully disables CAGS, this can go either way since GM has not made any statements at all regarding making encryption publicly available or CAGS on C7 being defeat friendly.
#47
But even so, how about a simple solution.. unbolt the solenoid from the transmission, so when it actuates it does not interfere with the shift lever.
#48
Any reason the Viper can't be defeated by putting in a blown smart fuse for the solenoid, like I did and many do on the Corvette?
As I said, hopefully GM will not copy Chrysler with this approach while trying to please the environmental regulators.
#49
120k miles on Manual transmission skip shift equipped vehicles and clearly I never activate it on my cars. I believe shifting out of first gear after 21 mph or 19mph does not allow the skip shift to activate..
(when at proper operating temperature)
Its such a non event for me...I have for years wondered why CAGS is so hated...
I never shift out of first at such a speed so CAGS never activates..
JMO and I wonder if anyone else out there never sees ..or so rarely sees CAGS activate in their cars its a non event as long as it helps the General avoid gas guzzler taxes etc..
#50
#51
#52
If you purchased a spare solenoid and mounted it to the car's superstructure near the transmission, and then unplugged the solenoid in the transmission and then plugged in the spare solenoid, wouldn't you defeat the CAGS yet would have a solenoid in the circuit to prevent CEL's?
#53
I HOPE I'M WRONG... but here is my prediction:
#1 - Like AFM, CAGS on the C7 will not be straightforward to defeat.
#2 - CAGS defeat devices will not be available as aftermarket equipment.
My reasoning (and again; I HOPE I'M WRONG): Like AFM, CAGS activates during EPA fuel economy test cycles, and therefore it affects the GM CAFE. The EPA is increasingly alert to OEMs "gaming" emissions and FE tests (e.g., by employing anything that can be easily deactivated) and aftermarket equipment equipment companies selling "defeat devices" (the legal term used in lawsuits that have cost OEMs $100 million in one case, and aftermarket equipment companies $6 million in another case).
#54
here is the connection.
#55
Of course, as we all know, the 2.2K ohm resistor in place of the Corvette's solenoid(aftermarket CAGS eliminator) fools the computer into believing the solenoid in still in the circuit, when it isn't. The electrical connector is nothing more then a two wire waterproof connector. I find it hard to believe the Viper does not have something similar to connect the transmission solenoid to the computer via a couple of wires. Disconnect the electrical connector on the Viper's Tremec TR6060 transmission and connect a cheap resistor(or an expensive solenoid) across the two wires and you have defeated the computer throwing a CEL.
#56
The point of my post about the spare solenoid was...there seems to be simple way to circumvent the Vipers computer and not get a CEL yet still not have the CAGS operating.
Now, I have seen indications that GM may disallow aftermarket tuning on C7, if GM does this, the CAGS may not be defeatable anymore. We shall see what actually will happen.
#57
K, maybe I did not make it clear, you can use the bypass module/resistor on the viper and it will work defeating CAGS. However, after about 6 starts and 100 miles, CEL will come on. Torque Management system configuration in 09/10 is responsible for this part. MOPAR offers a replacement ECU that I am guessing reconfigures TM to eliminate CAGS input altogether. This is why the only way you can defeat CAGS is through software. Since the software is locked and Chrysler will not release it, there is nothing anyone can do, breaking down the encription code can be very expensive and time consuming.
#58
That sounds as if the Viper looks at 6 cycles to see if the car was shifted into 4th gear when the computer engaged the CAGs and somehow looked to see if the engine was lugged down(or seeing the corresponding drop in engine RPM when shifting 1st to 4th after the shift was completed) vs just seeing if there is current flow through the solenoid(or CAGS eliminator resistor) as with the Corvette.
#59
1st has anyone actually tried with a second solenoid, or removing and letting the solenoid hang? Perhaps the computer does not see a current/voltage spike of a solenoid engaging.
2nd How does the computer know the car did not skip shift or not once the solenoid is defeated?
#60
