GM C7 specs
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Repeating what Tadge commented in the Car and Driver Interview was that their front to rear is close to 48F to 52R. This is great news !! But also important is the weight distribution from side to side and opposite corner to opposite corner. Using a 4 pad performance scale to analyze how much weight is on each individuel corner is very critical. With the driver in place the car will not be balanced from side to side unless they locate weight on the passenger side to offset the driver weight. I'll bet the battery is in the right rear or passenger side rear and the heavier of the two rear coolers (Differential and Transmission) is also in the right rear. All in order to balance weight from side to side. The torque of the motor will actually transfer weight. Thats why some motors have reverse crankshaft rotation. I was at a Ferrari event at Laguna Seca two years ago and noticed that one F1 car while on their stands would torque to the right and another F1 car right next to it would torque to the left. One of the motors was built for a right turn dominate track and the other was built for a left turn dominate track. The torque of a motor will assist in initiating a turn, and we know how much torque these Corvette motors are producing(gobs and gobs of torque). Take a look at these scales.
Received 4,377 Likes
You should probably wait until after the car is released to independent 3rd parties before you ask anymore questions. Otherwise you will only be frustrated by the answers. Please stop posting; I am only asking as I am concerned for your health. Stress is bad for for ones health.
Since that credible information would have to come from GM, and not a independent 3rd party, until it is released; you will not believe it since GM has no credibility with you. Why do you bother to ask?
Independent verification is just it. I would like to see GM back up their statement, with specifics under which this weight distribution claim applies and what conditions may change it. Apparently you and few others have a problem with people interested in seeing what lies behind the numbers? I would hate to think that the real strength in numbers as GM continues to say amounts to nothing more than gollubility of the potential buyers. Now, unless you have something of value to add, move on.
They have already told us how they are going achieve the weight distribution change, they have lengthed the wheelbase and have moved the engine back relative to the front axle line. The battery will be in the rear.
What specific information are looking for? You haven't stated that. Do you want corner weights? Do want you the weight of individual components and their position relative to the centerpoint of the footprint? What EXACTLY can GM provide that will satisfy you? Please be clear, concise, and quantitative.
I am adding something to the thread, I am seeking clarity, where you have not provided sufficient clarity.
Racer X is right. Tadge has already told us that its going to be close to 48F and 52R and the side to side and opposite corner to opposite corner is going to be optimized. You can even see it in the engine compartment. Heavier components on the passenger side to offset driver weight.
If you don't belive their general statements, you won't belive their specific statements. They are not going to release that information until they release the car.
You can bet your bottom dollar they have them. They know right where to locate everything. On any real serious sportscar these manufacturers know which side to locate their ancillary parts. You would think that a company like GM might have a test analysis bed like this. Though they may be able to calculate off their cad cam software??????
http://www.racer.com/video-indycar-t...rticle/262201/
#33
Selling dealer did the repair and they have stayed tight for an additional 24,000 miles.
#34
How is it possible to claim 50/50 weight distribution without knowing the final weight of the vehicle? Now, I see the hp/tq have ESTIMATED attached to it but no such case with the weight distribution. Surely there will be a difference between sum and no sump and manual vs. auto and different wheel and tire combos.
#35
I really cant wait to see what "Nits" are going to be picked next. It is not all that long until these things hit the streets. Let the GM guys work, they will give us what they can when they can.
#36
NCM Lifetime Member
#37
#38
Under two weeks old and the dealer had to replace the axle nuts on my 09 Z06. No way they came loose after the car let the factory, with under 500 miles. They were not properly installed at the factory. Another GM fail.
#39
Not at all, this is based on pretty recent claims GM was making and the real life comparisson. For people like me, GM has to actually deliver on their promises and unsubstantiated claims. For me to make a change, there has to be a real reaon, nut just hype. I hate to repeat the same mistakes.
#40
Well simply take the last 2 gen's WD and apply it to the C7, simple, I'm pretty sure they're not going to deviate from that.
