Bash updates and info
Old 04-26-2013, 05:38 PM
  #201
SBC_and_a_stick
SBC_and_a_stick's Avatar
Originally Posted by Tool Hoarder
IMO that's a threshold the Corvette should not cross. Shoot... 3400lbs more like it. That's just getting too heavy.
I don't see a way it won't pass 3,500lbs. LS3 to LS9 was 90lbs in the engine alone, then there is the heat xchanger, dry sump, more coooling, bigger brakes, tires, wheels, stronger bits.
Thresholds are imaginary however, just increase it!
Old 04-26-2013, 05:50 PM
  #202
Jawnathin
Jawnathin's Avatar
Wow, 3300lbs... and that is for the non-Z51?
Old 04-26-2013, 06:01 PM
  #203
ByByBMW
Support Corvetteforum!
ByByBMW's Avatar
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
That is how I read it.
Old 04-26-2013, 06:04 PM
  #204
AirBusPilot
AirBusPilot's Avatar
Was famed top secret GM engineer "Big Gunnzz" at the event? You know, he's the one that was all over LS1tech leaking "top secret" engine specs, and how it would be well north of 500hp with E85?
lol
Old 04-26-2013, 06:09 PM
  #205
Hirohawa
Hirohawa's Avatar
Originally Posted by RC000E
The HUD looks amazing!
Thanks!
Old 04-26-2013, 06:13 PM
  #206
speedlink
speedlink's Avatar
AWD doesn't belong in a Corvette. If you want an AWD car, go buy something else.
Its the same as asking why don't they make a steak that tastes like spaghetti. If you really want spaghetti, go buy spaghetti. Leave the steak alone.
I like the analogy.
Old 04-26-2013, 06:17 PM
  #207
Hirohawa
Hirohawa's Avatar
Very disappointing that they are using all the high end expensive light weight material and still coming in heavier.
Remember the original rumors of 10% lighter? That would have been awesome!
Hope this changes on the Z06/ZR1 models.
Old 04-26-2013, 06:23 PM
  #208
max pl
max pl's Avatar
have we gotten any official mileage info yet?
Old 04-26-2013, 06:25 PM
  #209
OnPoint
The Consigliere
OnPoint's Avatar
Received 5,447 Likes on 2,272 Posts
Some details of note:
AFM is easily deactivated. It only works when you are in selected eco mode. When the auto is in manual mode it doesnt work either. Afm only activates at very low throttle and is hardly noticeable
Bose set a benchmark with this car when equipped with 10spkr system (add opt sub)
Stiffness with roof OFF still exceeds c6z
RC,
One question on this. If you're in a mode other than Eco, say Sport, and you shut the car off. When you re-start the car, does it default to Eco, or does it stay in Sport (or the other modes if they were one you selected)?
Thanks for all the info.
We all owe you a cold one.
Old 04-26-2013, 06:26 PM
  #210
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
Originally Posted by skank
If we assume the hp will be 480 like some here are projecting that would give a 6.87 power to weight ratio. 3298 divided by 480 =6.87. The C6 ZO6 is 3175 divided by 505=6.29. No wonder Mero is saying this will beat the old times at VIR by 4 to 5 seconds. New technologies with better front to rear weight distribution. It all adds up !!!!!
One could also assume that the horsepower is 450(which is the number GM is estimating, at this point in time) and the Z51's weight is 3348(heavier brakes, wheels, dry sump etc.). That would make the power to weight ratio 7.44.
Old 04-26-2013, 06:32 PM
  #211
BlueOx
BlueOx's Avatar
Who said 10% lighter? You bought into that? Or maybe you were the one making up and spreading the BS.
Old 04-26-2013, 06:38 PM
  #212
tome
tome's Avatar
RC;
By chance is there an accessory display? I am curious as to what the Optional Stingray sill plate looks like... ie painted / polished / ???? Picture would be awesome if available.
THANKS!!!!!
Old 04-26-2013, 06:42 PM
  #213
Bill17601
AIR FORCE VETERAN
Bill17601's Avatar
I lost 8 lbs which is not 10%. However I did make up the extra weight of the iron exhaust manifolds. I am so proud...
Old 04-26-2013, 06:51 PM
  #214
JoesC5
JoesC5's Avatar
Last fall, people were speculating the weight would be around 3000 pounds(including me). That's around 5.6% lighter, but nowhere near 10% which would be 2887 pounds.
Old 04-26-2013, 07:11 PM
  #215
Hirohawa
Hirohawa's Avatar
So rumors aside BlueHair - are you considering the weight gain a win?
I'm curious how even you will market, uh I mean spin this as a positive.
Hint - for sports cars weight is bad.
Old 04-26-2013, 07:12 PM
  #216
RC000E
RC000E's Avatar
Originally Posted by OnPoint
RC,
This has been asked, but I need to be clear. There are several "modes"...some that stay on, some that dont.
Let me be 100% and get back to you tomorrow before I mispeak.
Yep...i'm fairly certain that put z51 under 3400.
Z06 will use some additional methods to shave weight, while adding...3500 won't happen.
lol
Old Big Gunz didnt make it...lol
Yep...standard equip carbon roof and hood on every vette. Cant say they didnt do everything possible to keep weight down.
Gas mileage...no
Originally Posted by tome
RC;
THANKS!!!!!
There is a display with things added daily....i'll see what I can do.
Old 04-26-2013, 07:15 PM
  #217
BlueOx
BlueOx's Avatar
Hint...you wouldn't know the difference.
Hint...you thinking it would be 10% lighter means you are an idiot.
To Bash updates and info
Old 04-26-2013, 07:18 PM
  #218
sam90lx
sam90lx's Avatar
Grounded to the Ground!
Old 04-26-2013, 07:19 PM
  #219
sam90lx
sam90lx's Avatar
Gas mileage...no
Say What! The Z06 at 3500 lbs??
Old 04-26-2013, 07:22 PM
  #220
RC000E
RC000E's Avatar
Wont exceed 3500 i meant...no way. I see z06 in the 3400's...maybe less if they pull somethin crazy off.
You have to consider that z51 is near a c6z in that it has sump system, cooling systems and aero parts. So, the mass of c6z06's already exists on c7z51 nearly. Only weight to be added on z06 would be bigger brakes, bigger wheels/tires and anything else under the hood. You could see a carbon hatch and body though, lighter seats, you name it.
Quick Reply: Bash updates and info
