Will NPP be integrated into the Driver Mode Selections?
Scraping the splitter.
And if not, then what does "Exhaust Mode" represent in the matrix that RC posted from the bash?
The italicized and greyed items are "if available" (optioned) on the car, but NPP would be an option too. Obviously FE4 isn't going to be on all cars, so MSRC and PTM wouldn't always be applicable, e-LSD is on Z51 cars only and shift modes would be for A6 cars only. What am I missing?
http://forums.corvetteforum.com/1583744716-post166.html
http://forums.corvetteforum.com/1583750174-post289.html
S.
S.
So is the fact that it was not italicized as an "if equipped" item on the Driver Mode matrix a typo? All cars will have a variable "exhaust mode" whether equipped with NPP or not?
S.
S.
There are valves for AFM so that is likely what they are speaking of, not NPP.
AFM valves closed when in Eco mode so the car doesn't sound dumb when operating on 4 cylinders.
My guess is that Track mode will keep the NPP valves always open and sport mode will open the valves at a lower rpm than normal mode.
S.
Aftermarket system ASAP
Have a feeling most people will keep it set on Sport or Track.
Also, NPP option comes with an on/off electronic button. No more aftermarket needed!!!!!!!!!!!!!!!!!!!
AIR FORCE VETERAN
In my opinion the NPP is separate from the track mode setting and we are getting them confused. I think the track mode position on the exhaust system can be utilized without NPP.
Could this be possible?
Yes, but I do not think it changes anything on cars without NPP. The other valve is there for 4 cylinder mode.
